How do I asses the % of light transmission that passes through glass
The discussion revolves around assessing the percentage of light transmission through various types of glass, particularly in the context of building solar panels. Participants explore methods for measuring light transmission and the implications of different glass types on solar energy applications.
  • Experimental/applied
  • One participant suggests measuring light intensity before and after the glass to determine transmission.
  • Another participant recommends using a photodiode as a suitable instrument for measuring light intensity.
  • It is noted that different frequencies of light may be attenuated differently by the glass, which could affect measurements.
  • A photometer is mentioned as a general device for measuring light transmission, but it is emphasized that results will vary with wavelength.
  • Participants discuss the use of spectrometers for a more detailed analysis of light transmission across different wavelengths.
  • One participant highlights the importance of knowing the spectral makeup of light when using photodiodes for accurate readings.
  • A suggestion is made to use a thermopile detector, which has consistent responsivity across wavelengths, for measuring light transmission.
  • A practical approach is proposed to test glass by using a small solar cell to observe its effect on power generation.
Participants express multiple competing views on the best methods and instruments for measuring light transmission through glass. There is no consensus on a single approach, and various factors such as wavelength dependence and practical testing methods are discussed.
Participants mention the need to consider the specific wavelengths of light relevant to solar applications, indicating that the discussion is limited by the assumptions about the types of glass and the intended use in solar technology.
This discussion may be useful for individuals interested in solar energy applications, particularly those looking to evaluate the performance of different types of glass in solar panel designs.
johnstar
I am currently building a solar panel. I have sheets of glass that I collected, some is saftey glass and some are tempered (probably the same). I have read that Low Iron Tempered glass has 91% light transmission. How do I test the glass that I have for its light transmission?
Thanks
Science news on Phys.org
Measure light intensity before entering glass, measure on the other side, compare.
Thanks Borek. What instrument is best to use to measure the light?
A photodiode.
BTW, you DO know that different frequencies will be attenuated differently, don't you?
Zz.
OK, Zz already addressed the problem, while I was busy with other things.
In general device you are looking for is called a photometer. However, whole thing is not as easy as you seem to be thinking, as the result will depend on the wavelength - in other words, transmission for different colors will be different. (When we speak about wavelength and/or frequency, we speak about the same thing). So, before you will want to measure something, you have to know which part of the spectrum you are really interested in. Or, if you are thinking about solar panel used to heat the water, you will be interested in transmission of not only visible light, but also about infrared.
Broadband detectors with very flat absorption spectra do exist for lasers: www.gentec-eo.com. You could simply focus sunlight on one.
Perhaps they also exist specifically for sunlight.
The easiest/fastest way to completely characterize the glass in the way that ZaperZ is talking about is to use a spectrometer. There are a lot of cheap (relative of course, ~3kish) compact prism spectrometers that do an amazing job of this. The one i use all the time is an Ocean Optics HR-4000. Since you said you're trying to build the solar panels yourself I'm going to assume that you don't want to spend that much on a spectrometer to do this. That said here's what you would do if you can get a hold of one.
What you need:
White light broadband source
Your glass
Spectrometer
Generally you take a dark spectra and subtract it to get rid of some of the electronic noise. Then take a spectra without the glass in the way. Insert glass and take another spectra.
Use the transmission calculation on the spectrometer to figure out what wavelengths are being absorbed and at what percentages. You could also do this with a grating spectrometer and step through the wavelengths but that will be even harder, although possibly cheaper since you could find one on ebay.
The real question is do you really need to know the absorption coefficients for that glass at different wavelengths? I would say no. Because the responsivity of a photodiode changes with wavelength you won't get an accurate power reading from one because you don't know the spectral makeup of the light hitting it.
However, as Dr Lots-o'watts said above a broadband detector (usually called a thermopile detector) will do a very good job of this because the responsivity changes very little with respect to wavelength. They are still pretty expensive (1kish new) but you may be able to buy the thermopile by itself somewhere and use an op-amp circuit to amplify if needed.
When you are going to buy glass, take a small hand-held solar battery charger, or just a small solar cell hooked up to a meter. See if the glass blocks the power generation, or to what extent it does.
My solar charger doesn't work at all in my car, because the windows block the specific wavelengths it needs, even though it doesn't appear dark to the eye. So it's best to test against the real use.
Thansk JDlugosz that seems a simple and effective way. The glass is for a PV solar design and I have them ready to go.
  • · Replies 20 ·
  • · Replies 207 ·
16K
  • · Replies 24 ·
  • · Replies 19 ·
21K
