Helicopter rotor has four blades
  • Thread starter Thread starter Whatupdoc
    Helicopter Rotor
The discussion focuses on calculating the linear speed of a helicopter rotor blade with a length of 3.90 meters, rotating at a speed of 480 revolutions per minute (rev/min). The correct formula for linear speed is V = 2πR/T, where R is the blade length and T is the rotational speed. After applying the values, the linear speed is determined to be 0.05105 m/s. The calculation confirms that the initial answer provided was incorrect.
  • Understanding of rotational motion and linear speed calculations
  • Familiarity with the formula V = 2πR/T
  • Basic knowledge of units of measurement (meters, revolutions per minute)
  • Ability to perform arithmetic operations involving π (Pi)
  • Research the principles of rotational dynamics in physics
  • Learn about the applications of linear speed in aerodynamics
  • Explore advanced calculations involving angular velocity and linear velocity
  • Study the effects of blade design on helicopter performance
Aerospace engineers, physics students, and anyone interested in the mechanics of helicopter rotor systems will benefit from this discussion.
Whatupdoc
A model of a helicopter rotor has four blades, each of length 3.90m from the central shaft to the blade tip. The model is rotated in a wind tunnel at a rotational speed of 480rev/min .
A.) What is the linear speed of the blade tip?
given
R= 3.9
T = 480
would it just be V= 2*pi*R/t
and got = .05105
someone helped me(not at this forum) and the answer is wrong. can someone help? isn't it just asking for the velocity?
Well you say the rotational velocity is 480 rotations / minute
1 rotation at a distance R from the center is the cirumference of a circle, so the distance the tip travels in one rotation is : 2*Pi*Radius meters
D = 2*3.14159*3.90 = 24.5 meters
You say 480 Rot/Min => 480 (rotrotations/minute) * (24.5 meters/rotation) = 11760 meters per minute.
Yes, you are correct. The linear speed of the blade tip can be calculated using the formula V = 2πR/T, where V is the linear speed, R is the length of the blade, and T is the rotational speed in revolutions per minute (rev/min). Plugging in the given values, we get V = 2π(3.9)/480 = 0.05105 m/s. It is possible that the answer you were given is incorrect.
10K
9K
