Rabbit vs. Tortoise: A 100-m Race
  • Thread starter Thread starter huong03
    Race
The forum discussion centers on a race between a rabbit and a tortoise over 100 meters, where the tortoise moves at a constant speed of 10 cm/s and the rabbit initially naps for 16 minutes before accelerating at 0.15 m/s². The tortoise completes the race in 1000 seconds, while the rabbit, despite its nap, covers 120 meters in the same time, thus winning the race. The discussion also addresses the correct formulas for average velocity and average speed, confirming that the average velocity is calculated as vector/time and average speed as magnitude/time.
  • Understanding of kinematic equations, specifically s=ut + 1/2 at²
  • Knowledge of average velocity and average speed calculations
  • Familiarity with unit conversions to SI units
  • Basic principles of acceleration and motion
  • Study kinematic equations in-depth, focusing on their applications in motion problems
  • Learn about graphing velocity vs. time for different motion scenarios
  • Explore the implications of acceleration on race outcomes in competitive scenarios
  • Investigate the effects of initial conditions on motion, such as starting from rest
Students, educators, and enthusiasts in physics, particularly those interested in motion dynamics and problem-solving in kinematics.
huong03
1. A rabbit and a tortoise compete in a 100 meter race. The tortoise moves at a uniform speed of 10 cm/s. The rabbit took a nap for 16 minutes. After the rabbit wake up, he accelerates at a uniform rate of 0.15 m/s^2.
a) Draw a time vs. velocity of the motion of the tortoise and the rabbit? (I'm clueless!)
b) How long does it take for the tortoise to complete the race?
(It takes the tortoise 1000 seconds to win the 100 meter race, right?)
c) How far has the rabbit moved at this time?
d) Who won the race? The tortoise, right? but why?
e) If the rabbit had taken a 15 minutes nap instead, what is his required acceleration for the race to be tie?
2. Is the following formula right?
a) average velocity = (vector)/time
b) average speed = lmagnitudel/ time
Please help, thanks.
Use formula
[tex]s=ut+\frac{1}{2}at^2[/tex]
[tex]s_{tortoise}=0.10t[/tex]
[tex]s_{rabbit}=\left\{\begin{array}{cc}0,&\mbox{if}\ t<\ 960\ s\\<br /> \frac{1}{2}*0.15*(t-960)^2, &\mbox{if}\ t\geq\ 960 s\end{array}\right[/tex]
[tex]v_{tortoise}\frac{ds_{tortoise}}{dt}=0.10[/tex]
[tex]v_{rabbit}=\frac{ds_{rabbit}}{dt}=0.075*(t-960)^2\ for\ t\ \geq\ 960 s[/tex]
You have got your part (b) correct.
Substitute t=1000 s into the 3rd equation to get 120 m.
Substitute [tex]s_{rabbit}=100\ m \ to \ find \ the\ time\ t\ taken\ by\ the \ rabbit\\<br /> \ to\ reach\ 100\ m \ to\ get \ t=996.5 \ s.[/tex]
Unfortunately, the rabbit won the race.
Part (d)
[tex]s_{rabbit}=\left\{\begin{array}{cc}0,&\mbox{if}t<\ 900 s\\ \frac{1}{2}*a*(t-900)^2, & \mbox{if} t\geq\ 900 s\end{array}\right[/tex]
Substitute t=1000 s, time taken by the tortoise to finish the race = time taken for tie to happen, and s=100 m to get the answer.
Convert anything into SI units first. Initial velocity, u, for the rabbit is 0 because it starts from rest.
Can't help you with the next question, not clear enough...
Mistake Correction
[tex]v_{rabbit}=\frac{ds_{rabbit}}{dt}=\frac{1}{2}*0.15*2*(t-960) = 0.15t-144\ for\ t\ \geq\ 960 s[/tex]
The graph is attached.
9K
