Patterns of remainders when dividing x^n/n
  • Context: Graduate
  • Thread starter Thread starter ershi
    Patterns
This discussion focuses on the patterns observed when dividing the expression x^n by n! and analyzing the resulting remainders. Specific examples include the remainders of x^3/3! yielding a repeating pattern of 1 2 3 4 5 0 and x^4/4! producing a sequence of perfect squares. Additionally, the discussion highlights the behavior of quotients derived from x^3/3!, revealing a secondary pattern through successive differences. The author seeks explanations for these recurring patterns and their mathematical significance.
  • Understanding of factorial notation (n!)
  • Familiarity with polynomial expressions (x^n)
  • Basic knowledge of number theory and sequences
  • Experience with integer division and remainders
  • Explore the properties of factorial growth and its impact on polynomial division
  • Investigate the concept of modular arithmetic and its relation to remainders
  • Learn about generating functions and their applications in number theory
  • Study the theory of sequences and series, particularly focusing on differences and patterns
Mathematicians, educators, and students interested in number theory, particularly those exploring polynomial behavior and factorial relationships in mathematical sequences.
ershi
I observed some patterns in some series involving
taking the expression x^n and dividing it by n!, and looking at the remainder for each x, starting with x=0 or x=1
I was wondering if there is some kind of explanation of the patterns that seem to be present
For example, looking at the remainders of the divisions
X^3/3!
or
X^4/6
starting with x=1 and increasing x by 1 will yield (each number separated by a space)
1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 ...
Which shows an obvious pattern
Also, looking at higher n:
X^4/4!
or
X^4 /24
1 16 9 16 1 0 1 16 9 16 1 0
which seems to be a repeating string of 1 16 9 16 1 0
with each number being a perfect square between 0 and 24
Another example, looking at the remainders of
X^5/5!
or
X^5/120
yields
1 32 3 64 5 96 7 8 9 40 11 72 13 104 15 16
There is a pattern here where each odd-positioned number in the series
is simply the value of its place in the list,
whereas the even-positioned numbers always increase by 32 until they exceed 120, and then "overflow" over the value of 120 and so the next value starts over with the overflow added to 0
Also, there is something more involved I noticed with
x^3/3!
when you look at the QUOTIENT
For the first several values of x, these are the quotients (integer division)
0 1 4 10 20 36 57 85 121 166 221 288 366 457 562 682 818 972 1143 1333
Now I did a process where I take the difference of each two adjacent numbers and create a new series.
(Ex. 1st number in new series is 1-0, 2nd is 4-1, 3rd is 10-4, 4th is 20-10)
This yields
1 3 6 10 16 21 28 36 45 55 67 78 91 105 120 136 154 171 190
Now doing the process AGAIN yields
2 3 4 6 5 7 8 9 10 12 11 13 14 15 16 18 17 19
This is a pattern here where there are 4 numbers that increase steadily by 1, then the next two numbers in the series are transposed (switched) from this normal ordering.
Then there are four more numbers in normal order, then two that are switched, etc.
Note that at the beginning there are only three numbers in order. I think this is because I started generating numbers with x=1 and not x=0
I was wondering if there is are any explanations why these patterns exist, and I would think there are several other patterns involving this idea of dividing x^n/n!
for me these just happen no particular reason as to why such pattern exists
I wondered if it had to do with another thread I posted, about a factorial value being obtained through a process of differences with x^n series.
This factorial value might have some significance for this case too, because in effect we are looking at a sort of constant incrementing value in the other problem, and in this case the factorial is used as a divisor, which is similar to having a fixed increment. We observe how much the remainder is after the last possible increment.
I really don't understand all the necessary notation or other number theory principles to formalize all this.
  • · Replies 26 ·
  • · Replies 21 ·
