Why do we lean when carrying heavy objects
  • Context: High School
  • Thread starter Thread starter zorro
The discussion revolves around the reasons why individuals tend to lean to the opposite side when carrying heavy objects. It explores concepts related to balance, torque, and the center of mass, with a focus on the physical principles involved in maintaining equilibrium while lifting.
  • Homework-related
  • Some participants suggest that leaning to the opposite side acts as a counter-balance to maintain a stable center of gravity, thereby reducing strain on muscles and the skeletal system.
  • One participant requests a detailed explanation involving torque and center of mass, indicating a desire for a deeper understanding of the mechanics at play.
  • Another participant asserts that maintaining zero torque of contact forces about the center of mass is essential for equilibrium, explaining that this occurs when the vertical line through the center of mass intersects the base surface within the contact area.
  • One participant expresses uncertainty about the clarity of the explanation regarding torque and equilibrium, seeking further detail.
  • A later reply emphasizes that for torque to equal zero, the net upward force from the base must align with the force of gravity acting through the center of mass, highlighting the importance of balance and stability.
  • Some participants express a lack of mathematical understanding, attributing the leaning instinct to a natural response rather than a calculated action.
Participants generally agree on the concept of leaning as a counter-balance mechanism, but there is no consensus on the clarity of the explanations provided, particularly regarding the mathematical aspects of torque and equilibrium.
Some statements depend on specific definitions of torque and equilibrium, and there are unresolved questions about the clarity of the explanations related to these concepts.
zorro
When we lift heavy objects, why do we tend to lean to the opposite side?
Counter-balance. We try to maintain a centre of gravity that lessens the strain on our muscles and skeletons.
I need a more detailed explanation in terms of Torque, centre of mass etc
Sounds like a homework question to me. Why don't you attempt to describe how it works?
No, this is not a homework question.
I read in my book that "The torque of the contact forces about the centre of mass should be zero to maintain the equilibrium. This may happen only if the vertical line through the centre of mass cuts the bas surface at a point withing the contact area or the area bounded by the contact points. That is why a person leans in the opposite direction when he or she lifts a heavy load in one hand."
The second sentence is not clear to me. I need a more detailed explanation.
Sorry, man... it's beyond me. It's just an instinct to lean away from the load. I don't know from math.
The only way to have torque equal to zero is if the net upward force from the base is exactly in line with force of gravity. Gravity acts through the center of mass, so if a line from the center of mass falls outside of the base, there's no way for the force on the base to line up and cancel the force of gravity. This is the basis of balance and stability.
See: http://dev.physicslab.org/Document.aspx?doctype=3&filename=RotaryMotion_CenterMass.xml"
Thanks, I got the concept :)
  • · Replies 20 ·
  • · Replies 54 ·
  • · Replies 18 ·
  • · Replies 19 ·
