Thread Closed
Linear Combination of Primes
Share Thread Thread Tools
Sep5-10, 05:36 PM   #1
Was thinking a bit about linear combination of primes and my conclusions are bellow. I presume their is some theorem to capture this but I don't know it's name.
If p1 p2 are primes and n1 or n2 are positive integers, then there should be unique a minimum n1 n2 pair such that:
[tex]x=p_1n_1+p_2n_2 \pmod{p_1p_2}[/tex]
and all solutions should be of the form p_1n_1+p_2n_2 + m* p_1*p_2
Now If we introduce a third prime we know x satisfies:
[tex]x= a_1 \pmod{p_1}[/tex]
[tex]x= a_2 \pmod{p_2}[/tex]
[tex]x= a_3 \pmod{ p_3}[/tex]
where:
[tex]a_1 = p_2n_2+p_3n_3 \pmod{p_1} [/tex]
[tex]a_2 = p_1n_1+p_3n_3 \pmod{p_2} [/tex]
[tex]a_3 = p_1n_1+p_2n_2 \pmod{p_3} [/tex]
all solutions should be of the form: edit: part in quotes bellow needs to be fixed.
x+p1*n1
x+p2*n2
x+p3*n3
which are unique when x<p1p2p3
Now what happens if we wrap the space into something smaller then p1*p2*p3 as would be done in a hash table. Say, we wrap it into a power of two as is done in the java class hashmap.
Then I think this means
[tex]a1=a2=a3 \pmod{2^n}[/tex]
because
we want x to have unique values in the range 0 to 2^n so
[tex]x= a_4 \pmod{2^n}[/tex]
[tex]x= a_5 \pmod{2^n}[/tex]
[tex]x= a_6 \pmod{ 2^n}[/tex]
But the mod part of our equations is no longer pair wise prime and hence the solutions have to be equal with respect to modulo the greatest common divisor of the modulo part otherwise their is not a unique x. However, this looks quite difficult to satisfy so I think I might be missing something in terms of understanding.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Sep6-10, 11:37 PM   #2
Chinese remainder theorem
Sep7-10, 01:50 AM   #3
Quote by adriank View Post
Odd. I thought I mentioned that theorem in my original post. Anyway, what I was trying to do is use that theorem to map the unique solution space of a linear combination of primes in terms of their coefficients, and then see what consequences this has in terms of hash tables. The result is pretty trivial when you consider only two primes as you can apply modulo operations and then use the Chinese remainder theorem to show the range for which the linear combination representation is unique.
However if you have three primes the Chinese remainder theorem tells us that each unique value of a_1 a_2 and a_3 in
gives a unique value but we may not be able to produce all ordered pairs (a1 a2, a3) from a given (n1, n2,n3) because a1, a2 and a3 are defined as follows:
Let's look at a simple example p1=2 p2=3 p3=5 and
2+3=5 so
Here is a redundant mapping from (n1, n2, n3) to (a1, a2,a3)
(1,1,0)->(1,2,0)
(0,0,1)->(1,2,0)
I'm not sure if their are any other redundant mappings if we restrict, n1<p1, n2<p2 and n3<p3. Perhaps if we insure p3 is greater then the product of p1p2 we avoid redundant mappings.
Sep7-10, 02:37 AM   #4
Here is another linear combination prime question. Can every prime be constructed as a linear combination of smaller primes. It seems to work up to 17. Haven't tried it any further where the coefficient must be a positive coefficient less then the prime for which it is multiplied by.
Sep7-10, 03:24 AM   #5
I was looking at the solution to the Chinese remainder theorem on wikipedia. It seems there is a linear independent basis for the number which are the solution to the chinease remainder theorm:
Again, to begin, the product [tex] N=n_1n_2\ldots n_k[/tex] is defined. Then a solution ''x'' can be found as follows.
For each ''i''&nbsp;the integers [tex]n_i[/tex] and [tex]N/n_i[/tex] are coprime. Using the [[extended Euclidean algorithm]] we can find integers [tex]r_i[/tex] and [tex]s_i[/tex] such that [tex]r_in_i + s_iN/n_i = 1[/tex]. Then, choosing the label [tex]e_i=s_iN/n_i[/tex], the above expression becomes:
[tex] r_i n_i + e_i = 1 \,\! [/tex]
Although the basis vector [tex]e_i [/tex] isn't a prime number and it isn't necessarily positive. It's still an interesting arthritic way to uniquely construct a set of numbers.
Sep7-10, 07:25 PM   #6
Recognitions:
Homework Helper Homework Help
Quote by John Creighto View Post
Yes. You can prove this with strong induction and Bertrand's postulate.
Sep10-10, 12:27 AM   #7
take any linear combination of primes p,q, (not equal) ap+qb equal to 1, we are guaranteed there exist such a,b. then just multiply through by any prime you want.
so, all primes (in fact integers) are a linear combination of any two primes.
Sep15-10, 03:09 AM   #8
Quote by daveyp225 View Post
Interesting technique. Of course this doesn't work if we restrict our coefficients to positive numbers.
Thread Closed
Thread Tools
Similar Threads for: Linear Combination of Primes
Thread Forum Replies
Linear combination Precalculus Mathematics Homework 5
Linear combination Calculus & Beyond Homework 16
linear combination Linear & Abstract Algebra 1
linear algebra-linear combination Calculus & Beyond Homework 2
linear combination of phi(n) Quantum Physics 1
