Is the Smooth Structure on 2-Manifolds Unique?
The discussion centers on the uniqueness of smooth structures on 2-manifolds, exploring theoretical aspects and implications of different definitions of smooth structures. Participants examine the relationship between Riemann surfaces and differentiable structures, as well as the potential for multiple smooth structures on manifolds.
  • Technical explanation, Debate/contested
  • Some participants inquire about proving the uniqueness of smooth structures on 2-manifolds and reference the relationship between orientable smooth surfaces and Riemann surfaces.
  • One participant suggests that simply connected Riemann surfaces have a unique differentiable structure, which may imply a broader result for arbitrary Riemann surfaces through covering transformations.
  • Another participant questions the validity of the proposed proof, discussing the implications of diffeomorphisms between fundamental domains in universal covers and their relation to differentiable structures.
  • Several participants note that the definition of smooth structure is crucial, with one referencing Lee's Introduction to Smooth Manifolds, which suggests that there can be uncountably many smooth structures on manifolds that have at least one smooth structure of dimension greater than zero.
  • There is a discussion about the conditions under which transition functions between charts must be smooth, leading to the potential construction of multiple atlases that are not smoothly compatible.
  • One participant expresses confusion about the implications of unique smooth structures, suggesting that uniqueness may be defined up to diffeomorphism.
Participants express differing views on the uniqueness of smooth structures, with some arguing for uniqueness in certain contexts while others highlight the existence of multiple structures depending on definitions and conditions.
The discussion reveals limitations in the definitions of smooth structures and the assumptions underlying the proofs and claims made by participants. The relationship between homeomorphism and diffeomorphism in the context of Riemann surfaces and covering transformations remains a point of contention.
quasar987
How does one prove that the smooth structure on 2-manifolds is unique? Source?
Thx!
Thx!
While googling I found an old post on PF that argues along the following lines - and may be in the right direction of a proof - not sure.
Every orientable smooth surface has an atlas of charts that define a conformal structure. With this atlas the manifold is a Riemann surface. There is a famous theorem that states that every simply connected Riemann surface is conformally equivalent (and therefore diffeomorphic) to either a bounded disk, the entire complex plane, or to the standard 2 sphere.
So for a simply connected Riemann surface there is only one differentiable structure.
I think that an arbitrary Riemann surface can be obtained from the simply connected surface by the action of a discrete group of holomorphic covering transformations. perhaps this can be used to get the general result.
I am not sure this works.
Given two Riemann surfaces that are homeomorphic, choose fundamental domains in the unversal cover. These domains are diffeomorphic - by the theorem on conformal equivalence. Choose a diffeomorphism,D, between them.
The two respective groups of covering transformations are isomorphic. Choose an isomorphism,H.
Extend D to the entire covering space by the rule g(x) -> H(g)Dx.
Note that fg(x) -> H(fg)Dx -> H(f)(H(g)Dx).
This should define the diffeomorphism - I think.
I guess the idea is if the universal cover only has 1 differentiable structure then the manifold also only has 1.
It should be noted that it depends on your definition of smooth structure. If you use the definition of smooth structure given in Lee's Introduction to Smooth Manifolds, for instance, there are actually an uncountable number of smooth structures on all manifolds that admit at least one smooth structure of dimension greater than 0.
I am actually still a bit confused on this point myself. I believe it is because, given an atlas on a smooth n-manifold where n>0, if you have a chart [tex](U, \varphi)[/tex] and [tex](V, \psi)[/tex] such that [tex]U \cap V \neq \emptyset[/tex], then [tex]\varphi[/tex] only needs to be homeomorphic on [tex]U \backslash V[/tex] but must be diffeomorphic on [tex]U \cap V[/tex] so that the transition function [tex]\psi \circ \varphi^{-1}[/tex] is smooth. So, given a subset of a chart that does not intersect with any other chart, the coordinate chart does not necessarily need to be a diffeomorphism on that subset, and so you can use this fact to construct an uncountable number of atlases that are not smoothly compatible.
I believe that unique smooth structure means unique up to diffeomorphism.
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 16 ·
