How Are Reaction Forces Directed at Points A and D in a Supported Beam?
The discussion focuses on calculating the reaction forces at points A and D of a supported beam subjected to a force P of 1000N at an angle of 60 degrees. The beam is hinged at point A and supported by a frictionless roller at point D. The calculations yield R_D_y as 1420 N and R_A_y as -155 N, with R_A_x and R_D_x summing to 500 N. The conclusion clarifies that R_D only has a y-component due to the roller's ability to move along the x-axis, while point A has both x and y components due to its hinge support.
  • Understanding of static equilibrium equations: ∑Fy = 0, ∑Fx = 0, ∑Moments = 0
  • Knowledge of Free Body Diagrams (FBD) for visualizing forces
  • Familiarity with reaction forces in beams and supports
  • Basic trigonometry for resolving forces into components
  • Study the principles of static equilibrium in structural analysis
  • Learn about Free Body Diagram techniques for complex structures
  • Explore the behavior of reaction forces at different types of supports
  • Investigate the effects of varying angles and forces on beam stability
Engineering students, structural analysts, and anyone involved in mechanics of materials or beam design will benefit from this discussion.
ana111790
The uniform horizontal beam is hinged to the ground at A and supported by a frictionless roller at D. Distance A to B is 4 m, A to D is 3 m. A force P with a magnitude of 1000N makes an angle 60 degrees with the horizontal at point B. The total Weight of beam is 400 N.
By noting that 3/4 of the beam lie between A and D and 1/4 between D and B calculate the x and y components of the reaction forces on the beam at A and D.
[tex]\sum Moments_on_A[/tex] = 0
[tex]\sum Moments_on_D[/tex] = 0
[tex]\sum Fy[/tex] = 0
[tex]\sum Fx[/tex] = 0
I drew the given picture and then drew the Free Body diagram.
The direction of the Reactive forces on A and D is unknown so I chose a random direction (up and to the right) to portray them.
[PLAIN]http://img825.imageshack.us/img825/8133/drawing3.jpg
My calculations:
(AK, AL, AB and so on represent the distance between point A to point K, L, B respectively.)
1) [tex]\sum M on A[/tex] = 0 = -W_1*AK - W_2*AL - Psin(60)*AB + R_D_y*AD
Solved for R_D_y = 1420 N (rounded to 3 sig figs)
2) [tex]\sum M on D[/tex] = 0 = - R_A_y*AD + W_1*DK - W_2*DL - Psin(60)*DB
Solved for R_A_y = -155 N
3) [tex]\sum Fx[/tex] = 0 = Pcos(60) + R_A_x + R_D_x = 0
R_A_x + R_D_x = 500N
4) [tex]\sum Fy[/tex] = 0 = -W_1 - W_2 - Psin(60) + R_D_y + R_A_y = 0
R_D_y + R_A_y = 1270 N Answer in the book is given as: (not rounded)
R_D = 1421 N, R_A_x = -500N, R_A_y = - 155 N
So these answers are giving R_D to be going straight up, not at an angle, so R_D given in the book is equal to my R_D_y, which makes R_D_x = 0.
My question is why is that/ how would I know to set R_D_x = 0 ?
The reaction at point D has only a y-component because it is on a roller and free to move along the x-axis. Point D can only resist forces in the direction perpendicular to the beam. Point A is hinged and will have both x and y reaction components.
29K
