How does exp relate a Lie group to its Lie algebra?
  • Context: Graduate
  • Thread starter Thread starter geodesic42
    Algebra
The discussion centers on the relationship between Lie groups and their corresponding Lie algebras through the exponential map, exploring both theoretical and practical implications. Participants express confusion and seek clarification on how the exponential map relates to the structure of Lie groups, particularly in the context of representations and the uniqueness of groups derived from the same algebra.
  • Some participants express skepticism about the claim that the group can be represented as the exponential of the algebra, questioning the validity of this relationship given that different groups can share the same algebra.
  • It is noted that the exponential map provides a neighborhood of the identity in matrix groups, and finite products of elements from this neighborhood can generate the connected component of the group.
  • Participants highlight that the relationship between the algebra and the group is representation-dependent, with different representations leading to different group structures.
  • One participant points out that while the Lie algebra determines the local structure of the group, it does not uniquely determine the global structure, as seen in the case of SU(2) and SO(3).
  • Another participant mentions that simply connected groups with the same algebra are homeomorphic, but this does not hold for non-simply connected groups, which can lead to projective representations.
  • Concerns are raised about the surjectivity of the exponential map, with examples provided of groups that do not satisfy this property.
  • There is a discussion about the definition of the exponential map, with some participants suggesting that it should be understood in terms of integral curves rather than power series expansions.
  • One participant argues that for finite-dimensional matrix groups, power series expansions are valid and can describe trajectories in the group.
Participants generally do not reach a consensus on the relationship between Lie groups and their algebras through the exponential map. Multiple competing views remain, particularly regarding the role of representations and the implications of simply connectedness.
Limitations in the discussion include the dependence on specific representations, the ambiguity in the definition of the exponential map, and the unresolved nature of the surjectivity of the map in various contexts.
geodesic42
I feel like this has to have already been addressed somewhere, but apparently my search skills are lacking.
I rarely hear a mathematician talk about a Lie group and its generating algebra as related via the exponential map, though I have seen it somewhere. When I do see it, it requires more background development than I have immediate time for.
I ALWAYS see physicists talk about this relation (indeed, almost all physics-oriented math texts define the algebra by starting with the group and writing down the exponential). So I've heard many, many times: the exponentiation of the algebra gives the connected part of the group.
I don't believe this (or at least am confused by this). At least at an abstract level. Given how universal it is, I'd like to be convinced otherwise.
My first and most nit-picky gripe is: multiplication isn't defined on the algebra; a bracket is, which becomes a commutator when we find a rep and thus specifies only half of the multiplication operator (i.e. exp(algebra) makes no sense until we find a rep).
Second, su(2)=so(3) (the algebras, not the groups). exp is a 1-1 map. So we should find exp(su(2))=exp(so(3))...but this isn't the case. Choose [tex]\frac{1}{2}\{\sigma^i\}[/tex] as our generators for the 2-D rep, and we indeed get SU(2)'s multiplication table. Choose the canonical generators for the 3-D rep and we get SO(3), which obviously does not have SU(2)'s multiplication table. SU(2) and SO(3) are both completely connected (though SU(2) is simply connected), so the whole "it generates the connected piece" bit doesn't solve anything. So how can we possibly say Group=exp(Algebra) if different groups have the same algebra? I'm pretty sure the answer must be that the group we get out of exponentiating is rep-dependent since the other half of the algebra's multiplication table isn't specified until we choose one anyway.
tl;dr: How can we possibly say Group=exp(Algebra) if different groups have the same algebra?
Thanks!
But who says that it is so in general? In physics we usually deal with matrix groups. Exp(Algebra) gives you a neighborhood of identity. Finite products of such elements (from this neighborhood) will give you the connected component. For quite a number of applications that is all you need.
Details about different cases can be found in this paper:
"[URL surjectivity question for the exponential function of real Lie groups:
A status report[/URL]
Dragomir Z. Dokovic and Karl H. Hofmann
You said matrix groups. I.e. the answer is rep-dependent. So I was right?
It depends on what you mean by "answer". It depends on what kind of representations (continuity properties), and what kind of groups etc. we are talking about. Each problem may need a separate discussion.
If two Lie groups have the same universal cover they have the same Lie algebra. But the Lie algebra uniquely determines the simply connected associated Lie group
You have to be careful here, a matrix (Lie) group is a closed subgroup of [tex]\text{GL}(n;\mathbb C)[/tex] (most groups used in physics is of this kind). This is, however, NOT the same as representations.
This is not true. Generally, Lie groups are manifolds equipped with a group product compatible with the underlying differential structure. The corresponding Lie algebra is isomorphic to the tangent space at the identity element, and it is possible to construct a map EXP from the Lie algebra to a neighborhood around the identity element.
The answer to your question is not really related to representations. I think arkajad and Office_Shredder has answered your question, although very densely.
I original learned about all this from Cornwell "Group Theory in physics".
Chapter 10-11 does full justice to this topic.
The real Lie Algebra does not determine the structure of its corresponding Lie groups globally but only locally.
If G is a compact linear Lie group (such as SU(2) and SO(3)) every element of the connected subgroup of G can be expressed in the form exp(a) for some element a of the corresponding real Lie Algebra L. So if G is connected and compact (as SU(2) and SO(3) both are), every element of G has the form exp a for some a in L.
So you question is how come SU(2) and SO(3) are different?
This can occur because the exponential mapping from L -> G are not one-to-one maps.
For example, with SO(3), exp(theta.a) = exp ((theta+2pi).a).
So the maps exp:L->SU(2) and exp:L->SO(3) end up with different groups. In fact there is a 2-1 map from SU(2) to SO(3).
You can say this if the group is simply connected. So if two simply connected groups have the same algebra, they are homeomorphic. If a group is not simply connected, a representation of the algebra is a representation of the group only "up to a phase", i.e. a projective representation. For example, SO(3) is not simply connected, in fact it is doubly connected. To use Weinberg's words, the phase in the projective representation of SO(3) is then just a sign, which is precisely the classic example you mentioned.
Unfortunately, this isn't always true. For example, consider the simply connected group [itex]SL \left( 2 , C \right)[/itex], which is the universal cover of the restricted Lorentz group. There are elements of the simply connected [itex]SL \left( 2 , C \right)[/itex] that are not exponentials of the Lie algebra [itex]sl \left( 2 , C \right)[/itex], i.e.,
[tex]SL \left( 2 , C \right) \ne \exp \left( sl \left( 2 , C \right) \right).[/tex]
arkajad, Office_Shredder, and BruceG have given various aspects of the situation.
It is true that every element of [itex]SL \left( 2 , C \right)[/itex] can written as the product of two exponentials of elements of [itex]sl \left( 2 , C \right)[/itex], so [itex]\exp \left( sl \left( 2 , C \right) \right)[/itex] does generate [itex]SL \left( 2 , C \right)[/itex]. Note that [itex]SL \left( 2 , C \right)[/itex] is not compact.
The exp map is not necessarily surjective. In some case it is, we call such lie groups, exponential lie groups. Some example of exponential lie groups are nilpotent groups, and extension of nilpotent lie groups with diagonal action of a real line. However, in general, your claim is untrue. For example extend a Nilpotent lie group with a diagonal action of a complex torus. Such lie group is not exponential.
Vignon S. Oussa
I know less about lie groups and algebras than any other topic, hence I throw in my 2 cents. It seems to me part of the OP's problem is a tacit assumption that exp refers to a power series expansion, hence requires a multiplication. from my minimal experience, (reading the first 2-3 pages of a book on lie groups such as that by j.f.adams), exp is defined on a tangent vector by producing an integral curve in the manifold with that tangent vector at the identity and then running along it for time 1 in the manifold. Hence the surjectivity problem is equivalent to the coverage of a manifold by such integral curves, a problem in diff eq.
(of course it goes without saying that the primordial connection is that the lie algebra is the tangent space to the lie group at the identity. incredibly some books on lie algebras do not mention this fact.)
experts can no doubt correct the harm my ignorance does here.
I think that for finite-dimensional matrix groups there is nothing wrong with power series expansion. There are no multiplications, just powers of one matrix. Things nicely converge, you get a trajectory in the group. The only question is how far from the identity can you get this way.
You are correct, but to be more precise, the lie algebra is the vector space of left invariant tangent vectors based at the identity of the group.
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 19 ·
