Finite differences on scalar? Matrix?
  • Context: Graduate
  • Thread starter Thread starter divB
    Finite Matrix Scalar
The discussion revolves around the application of the Kth finite difference operator, denoted as \(\Delta^K\), on a polynomial sequence defined by \((-1)^n n^k y_n\). The participants clarify that without the finite difference operator, the expressions \(v_{n,k}\) would simply represent scalars rather than finite differences. The key question is how to compute the matrix \(\mathbf{V}\) from the finite differences, particularly when applying the operator to sequences of varying dimensions. The conversation highlights the relationship between the finite difference and the discrete differences of sequences.
  • Understanding of finite difference operators, specifically \(\Delta^K\)
  • Familiarity with polynomial sequences and their properties
  • Basic knowledge of matrix operations and representations
  • Ability to interpret mathematical notation and expressions
  • Research the properties and applications of finite difference operators in numerical analysis
  • Study polynomial interpolation and its relationship with finite differences
  • Learn about matrix representations of finite difference equations
  • Explore algorithms for calculating finite differences in multi-dimensional sequences
Mathematicians, numerical analysts, and students studying finite difference methods or polynomial sequences will benefit from this discussion.
divB
Hi,
In a paper I have
[tex]v_{n,k} = \Delta^K ( (-1)^n n^k y_n )[/tex]
with [tex]n = K, \dots , N-1[/tex], [tex]k = 0, \dots, K[/tex] and [tex]N = 2K[/tex]
where [tex]\Delta^K[/tex] is the Kth finite difference operator.
As you can see, all [tex]v_{n,k}[/tex] consistute an [tex](N-K) \times (K+1)[/tex] matrix.
So without the [tex]\Delta[/tex]'s, each [tex]v_{n,k}[/tex] would be a scalar. I do not see how to calculate the finite difference of a scalar?!
Well, probably it is not a finite difference. But can anybody tell me what could be meant with that?
Regards,
divB
I don't understand. You say that [itex]\Delta^K[/itex] is the "Kth finite difference operator" and ask what would [itex]v_{n, k}[/itex] be without the [itex]\Delta[/itex]? It would no longer be a finite difference!
(The finite difference of a scalar function, at some n, would be f(n+1)- f(n).)
Hi,
Yes, this is exactly my question! I do not understand how it is meant!
Maybe you can take a look at http://biblion.epfl.ch/EPFL/theses/2001/2369/EPFL_TH2369.pdf, page 55-56.
I again try to explain: Suppose you have a sequence [tex]y_n[/tex] consisting of N values. Now consider the expression
[tex](-1)^n P(n) y_n[/tex] where [tex]P(n)[/tex] is a polynomial of order K in the variable n. The authors argue that this term vanishes if K finite differences are applied. This yields equation 3.14-3.16 in the link above and can be written as matrix equation:
[tex] \Delta^K ((-1)^n P(n) y_n) = \sum_{k=0}^K p_k \underbrace{\Delta^K ((-1)^n n^k y_n)}_{v_{n,k}} = \mathbf{V} \cdot \mathbf{p} = 0[/tex]
My question is how to calculate the matrix V. The algorithm 3.1 in the link above tells me exactly what I have asked in the original post but I do not know how to actually calculate it.
It would be easier to understand if there would be just one dimension.
But this brings me to an idea: The finite difference is the difference dependent on n, isn't it?
So for the first column I set k=0 and have the sequence [tex](-1)^n n^0 y_n[/tex] and the column are just the discrete differences of the sequence?
E.g. if [tex](-1)^n n^0 y_n = \left\{1, 4, 9, 8, 10\right\}[/tex] then the first column would be [tex]\left[3 , 5 , -1 , 2\right]^T[/tex]?
And the same for columns 1,...K?
Maybe this is the solution?
Regards, divB
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 33 ·
