Simple Kinematics Question: Equation of Motion?
The discussion revolves around a kinematics problem involving a car's motion along a straight path. The original poster seeks clarification on the equation of motion, particularly how to apply it to a scenario where the car travels at a constant velocity before accelerating.
  • The original poster attempts to apply the equation of motion but expresses confusion about the role of acceleration and how it integrates with the initial velocity over time. They question the logic behind the formula and its application in the context of the problem.
Participants are engaged in clarifying the application of the equation of motion. Some provide insights into the separation of motion phases, while others attempt to address the original poster's misunderstandings regarding the formula's components. There is an ongoing exploration of how to correctly interpret the variables involved.
There is a noted lack of clarity regarding the definition of initial position and velocity in the context of the problem, as well as the timing of the acceleration phase. The original poster expresses a desire for deeper understanding rather than just a solution.
GladScientist
Hi everyone. I'm new here, and I would like some help understanding the equation of motion. It's a simple high school homework question, so I think you guys should be able to help me out here. I'm not sure if I'll be able to properly fit the question into the template, because I know how to answer the actual question... I'm just confused as to how or why it works the way it does.
A car is to travel along the X direction only. The car begins its journey at X=5m. The car then travels with a constant velocity of 3m/s for a time of 8 seconds. It is at this time the driver decides to increase the velocity and accelerates to 2m/sec/sec for 3 seconds.
I need to find the position from X=0.
So what I did is simply plug in the equation of motion.
Xf=X0+V0t+1/2at^2
So that gives me:
Xf=5m+3m/s(11s)+1/2(2m/s^2)(3s^2)
If I simply plug in the numbers, I get X=41m. But I'm pretty sure this is wrong. I think that it's fairly clear that I'm using the equation of motion wrong, because logically, it doesn't make sense.
So let's start by looking at the first part of the equation, Xf=X0+V0t.
Okay, that part makes sense. The final position is where you started plus how far you went.
But acceleration is where I don't quite catch on. First of all, shouldn't the amount of time spent accelerating be distributed to the velocity, since time spent accelerating is also time spent traveling at the original velocity? In other words, when the car accelerates to 2m/sec/sec, that time is also spent traveling at the original velocity, just with the acceleration included. So why isn't the original velocity added to the acceleration in the equation of motion?
And second, I don't understand the acceleration part of the equation itself. In this particular problem, the car accelerates at 2m/sec/sec for 3 seconds. So that means that it's speed should increase by 2, then 4, then 6, for a total of 12 extra meters. But the equation of motion's formula is 1/2(2m/s^2)(3s^2), which just gives me 3 meters.
So clearly, I either have something wrong, or I'm misunderstanding how the equation of motion is supposed to work. Can anyone shed some light on this problem?
Thanks.
The first part of the motion is uniform. Determine how far the car reaches during the first 8 s. You can apply the equation for motion with constant acceleration in the last 3 s.
ehild
Thanks but I still don't get why the formula for acceleration is 1/2at^2? It doesn't match up with what the numbers should logically be.
It is Xf=X0+V0t+1/2at^2, but X0 is the position of the car when it starts to accelerate and V0 is the velocity at the same time.
ehild
Xf=X0+V0t+1/2at^2
See here the part V0t is the distance covered by the car due to its initial velocity before acceleration starts and 1/2at^2 is the distance covered while uniform acceleration.
For the above question x=5+33+9=47m and x0+47 = 5 + 47 = 52 m
ehild
But how can it start accelerating at X0 when it doesn't accelerate (in the word problem) until after it's finished 8 seconds of traveling at the base velocity?
Please excuse me if I'm making myself look like an idiot, keep in mind that I'm very new to the mathematical aspects of physics.
This is not the same X0 as the position at the beginning of the motion.
Tell me please what is the position of the car after 8 s? x(8)=?
ehild
I get it, thanks guys.
  • · Replies 20 ·
  • · Replies 32 ·
