Register to reply
Observability and existence and uniqueness
by Aerostd
Tags: existence, observability, uniqueness
Share this thread:
Aerostd
#1
Sep11-10, 02:18 AM
P: 18
I have set up this problem for myself.
Let P be a system of the form
x' = Ax + Bu
y = Cx + Du
The definition of a "state" is:
"x(t) is a state for a system P if knowledge of x at some initial time t_{0} and the input u(t), t \geq t_{0} is sufficient to uniquely determine y(t) for t \geq t_{0}."
Let us consider only the free response (input 0). My understanding is that if x(t) is a state, then each selection of x_{0} will yield a unique y(t).
Now here is one definition for observability:
"A system P is observable if and only if the initial state x_{0} can be determined uniquely from its zero-input response over a finite time interval."
The thing that has been bothering me is this. If a system in unobservable, then that means that we can find two different initial conditions that give the same free response. Does that mean that if a system is unobservable, the existence and uniqueness conditions are violated? And if so, does that not mean that the x(t) we chose are not even states by definition?
2. Relevant equations
Here is an example. Suppose i have mass spring damper system.
x'' = -(c/m)x' - (k/m)x
We define our state variables as:
x_{1} = x
x_{2} = x'
Then,
x'_{1} = x_{2}
x'_{2} = x'_{1} = x'' = -(c/m)x_{2} - (k/m)x_{1}
Let my output be
y = x_{1}+x_{2};
Now, just for argument, suppose i define a third state variable
x_{3} = height of a random bouncing ball far away from the mass spring damper system.
My "state" is now x = [x_{1} x_{2} x_{3}]^{T}.
3. The attempt at a solution
I think it is safe to say that x_{3} will never appear in the output. The initial condition vector [1 1 10]^{T} and [1 1 20]^{T} will give the same free response. I know x_{3} is unobservable. I also think that since two different initial conditions give me the same output, therefore by definition, my choice of the state is not even a state since i do not get a unique output for two different initial conditions.
I think i am wrong. But i don't know where.
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
CEL
#2
Sep11-10, 04:28 AM
P: 639
Quote Quote by Aerostd View Post
x' = Ax + Bu
y = Cx + Du
x_{1} = x
x_{2} = x'
Then,
x'_{1} = x_{2}
Let my output be
y = x_{1}+x_{2};
For x_{3} to be a state variable of your system, you must write the dynamic equations describing its behavior.
In this case, knowing the initial state and the input (0 for the ball), you can determine the output y of the system. You can also know the state (value of the 3 variables) any time in the future.
What you can't do is to determine the initial state from observation of the output.
Aerostd
#3
Sep11-10, 09:41 AM
P: 18
Quote Quote by CEL View Post
My question is that if two different initial conditions give you the same free response, doesn't that violate the definition of a state?
CEL
#4
Sep11-10, 10:27 AM
P: 639
No. Read again the definition.
Think of a parallel RC circuit and take the voltage and current on the capacitor as state variables.
If you charge the capacitor with any voltage, the state at t = infinity will be current and voltage both equal to zero.
Register to reply
Related Discussions
Interval of existence / uniqueness Calculus & Beyond Homework 2
Existence and Uniqueness Theorem Calculus & Beyond Homework 0
Differential Existence and Uniqueness Calculus & Beyond Homework 1
Existence and uniqueness Differential Equations 4
Existence and Uniqueness Differential Equations 4
