Algebra II Help: Domain & Range of f(x) = 4x + 3
  • Thread starter Thread starter XSurferXe
    Algebra
The function f(x) = 4x + 3 is defined for x > -2, establishing the domain as (-2, ∞). The calculation of f(-1) yields -1, confirming the function's output for that input. The range of the function is all real numbers, represented in interval notation as (-∞, ∞). This analysis clarifies the concepts of domain and range in relation to linear functions.
  • Understanding of linear functions in the form y = mx + b
  • Knowledge of interval notation for expressing domains and ranges
  • Basic algebraic skills for function evaluation
  • Familiarity with the concept of real numbers
  • Study the properties of linear functions and their graphs
  • Learn about interval notation and its applications in mathematics
  • Explore the concept of piecewise functions and their domains
  • Investigate the relationship between domain, range, and function behavior
Students studying algebra, particularly those learning about functions, domain, and range concepts. This discussion is beneficial for anyone seeking to strengthen their understanding of linear equations and their characteristics.
XSurferXe
im perplexed by this question...we were never teached domain and range... so please help in an easy way with this question : "Suppose the function f(x) = 4x + 3 is defined for x > -2. "
A. Find f(-1) ... i got -1
B. Find the domain and range of F ... here I am lost PLEASE help
Domain is the the set value x for f(x) to be defined.in this case, it is given as [tex]x \geq\ -2[/tex].
Range is the set of value of f(x) for the domain. f(-2)=-5. so, the range is [tex]f(x)\geq \ -5[/tex]
Hi there,
I can definitely help you with this question! First, let's talk about the function f(x) = 4x + 3. This function is in the form of y = mx + b, where m is the slope and b is the y-intercept. In this case, m = 4 and b = 3.
Now, let's look at the given condition that the function is defined for x > -2. This means that the function is only valid for values of x that are greater than -2. So, any values of x that are less than or equal to -2 are not part of the domain of the function.
To find f(-1), we simply substitute -1 in place of x in the function. So, f(-1) = 4(-1) + 3 = -4 + 3 = -1. Great job, you got it right!
Now, for the domain and range of the function. The domain of a function is the set of all possible input values, or x-values, for which the function is defined. In this case, since the function is only defined for x > -2, the domain is all values of x that are greater than -2. So, in interval notation, the domain would be written as (-2, infinity).
The range of a function is the set of all possible output values, or y-values, that the function can produce. In this case, since the function is in the form of y = mx + b, we know that the range will be all real numbers because there are no restrictions on the output values. In interval notation, the range would be written as (-infinity, infinity).
I hope this helps to clarify the concept of domain and range for you. Just remember, the domain is the set of all possible x-values and the range is the set of all possible y-values. Keep up the good work!
  • · Replies 23 ·
