Groups of prime order are cyclic. (without Lagrange?)
The discussion centers on proving that groups of prime order are cyclic without relying on Lagrange's theorem. The participants explore the possibility of establishing an isomorphism between a group G and the additive group of integers modulo p, denoted as Z/pZ. They conclude that while it is challenging to construct this isomorphism without invoking Lagrange's theorem, understanding the properties of Z/pZ and homomorphisms is essential for the proof.
  • Understanding of group theory concepts, particularly cyclic groups.
  • Familiarity with isomorphisms in abstract algebra.
  • Knowledge of the properties of Z/pZ, the additive group of integers modulo p.
  • Basic understanding of homomorphisms and their properties.
  • Study the properties of cyclic groups in detail.
  • Learn about isomorphisms and their applications in group theory.
  • Investigate the structure of Z/pZ and its significance in group theory.
  • Explore alternative proofs of group properties that do not rely on Lagrange's theorem.
This discussion is beneficial for mathematicians, particularly those specializing in abstract algebra, group theorists, and students seeking to deepen their understanding of cyclic groups and their properties.
TwilightTulip
I know full well the proof using Lagrange's thm. But is there a direct way to do this without using the fact that the order of an element divides the order of the group?
I was thinking there might be a way to set up an isomorphism directly between G and Z/pZ.
Clearly all non-zero elements of Z/pZ are generators, so sending any non-identity element of G to any equivalence class of 1,...,p-1 should induce an isomorphism... but how to prove it?
I guess not then :biggrin:
I was thinking that since [tex]\phi(1)->g \neq e[/tex] works, there must be a way to construct such an ismorphism that makes it easy to "play" with the properties of a group to get the isom to work out.
I suppose simply showing that [tex]\phi(0) = e=g^0,g^1,...,g^{p-1}[/tex] are all unique would be enough. But this would e hard without using the fact that the order of an elt must divide p, unless of course this is provable without using lagrange?
I;ve come up with a way, but it assumes we know the properties of Z/pZ and a certain property of homomorphisms: that the order of [tex]\phi (k)[/tex] divides the order of k, which is p.
i guess you are essentially using lagrange for cyclic groups, which is all you need here.
  • · Replies 26 ·
