Resistance dependence on temperature for metals
The discussion centers on the relationship between temperature and electrical resistance in metals, specifically addressing the classical explanations for increased resistance due to ion vibration. The author critiques the common analogy of electron scattering by vibrating ions, proposing a more nuanced model that considers the directional interactions between electrons and ions. The author concludes that at elevated temperatures, the majority of interactions between electrons and ions tend to impede electron flow, thereby increasing resistance. This perspective aims to provide a clearer understanding suitable for high school physics education.
  • Understanding of basic electrical concepts, including current and resistance.
  • Familiarity with atomic structure and the behavior of electrons in conductors.
  • Knowledge of thermal effects on materials, particularly in metals.
  • Basic grasp of classical mechanics and motion.
  • Explore the concept of electron mobility in metals at varying temperatures.
  • Research the Drude model of electrical conduction in metals.
  • Investigate the effects of temperature on resistivity in specific metals, such as copper and aluminum.
  • Learn about the role of phonons in electrical resistance and thermal conductivity.
High school physics educators, students studying electrical properties of materials, and anyone interested in the fundamental principles of conductivity and resistance in metals.
furryelephant
I'm writing some high school physics teaching animations and I need to make sure I have the right idea for why increasing the temperature of a metal increases its resistance.
It's high school, so I need some classical analogy which isn't just blatantly wrong or stupid.
The explanations I have always heard involve increased movement of the metal lattice disrupting (scattering) the flow of electrons.
It is always presented as intuitively obvious that:
1. Increased ion vibration would obviously cause more frequent interaction with electrons.
2. Electron collision with vibrating ions would necessarily slow the progress of the electrons down the wire.
Neither of these two assumptions are remotely intuitive to me.
My feeling is that
1. is like running down a corridor with a sliding door that opens and shuts continuously. If you can't control your speed, would you rather a high frequency door or a low frequency one to avoid running into it? - seems to me like swings and roundabouts unless there is a second order effect to do with relative size of you and door.
2. we can ignore the component of collisions that cause motion perpendicular to the drift direction since the electrons are still being accelerated by the field - analogous to droppping a ball and launching it horizontally.
So the only interactions we need to worry about are the ones where the component of the ion's motion is in the same sense as drift direction.
Now these interactions could either
a. tend to reduce the drift rate
b. tend to increase it
c. have no effect
My model is that they tend to reduce it.
If the maximum velocity of the ion vibration is much higher than the typical electron velocity at interaction then the electron can only interact with the ion under these circumstances (let's imagine that drift direction is left to right):
a. the ion has just has just gone past it's left maximum and is moving slowly right (the electron would have a 'soft landing' and so this would tend to hasten its progress down the wire since it wouldn't be smacked back the way it came)
b. the ion is just about to reach it's right maximum (the electron would have a 'soft landing' and so this would tend to hasten its progress down the wire since it wouldn't be smacked back the way it came)
c. the ion is moving at any velocity to the left (the electron will be batted back up the wire by the approaching ion, which will reduce its progress down the wire)
Most of the time when the ion is moving from left to right the electron can't interact with it because it's not going fast enough.
This means the majority of the possible interactions tend to knock it back to where it came from rather than giving it a soft landing.
At high school level you don't want to get too involved (these explanations look a lot simpler when they're animated) but I want to avoid telling them a story that is just blatantly wrong.
Comments on my ideas, please or alternative suggestions.
Thanks
It's like trying to move down a corridor full of people. If all the people drift along the same direction things go better than if the people are all bouncing off the walls and colliding with each other.
Seems to me :smile:
  • · Replies 36 ·
  • · Replies 30 ·
