Calculating Locomotive Force: Tension in 2nd & 3rd Cars
  • Thread starter Thread starter chrizzilla
    Force Locomotive
The discussion focuses on calculating the tension in the coupling between the second and third freight cars of a locomotive pulling 15 cars, each weighing 37,000 kg. Using the formula F=ma, the force exerted by the first 13 cars is calculated to be 346,320 N when the train accelerates at 0.72 m/s². The initial confusion regarding the application of the formula was resolved by recognizing that only the force of the 13 trailing cars needs to be considered for this specific tension calculation.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of mass and weight in physics
  • Familiarity with the concept of tension in mechanical systems
  • Ability to perform calculations involving acceleration and force
  • Study the implications of Newton's Laws in multi-body systems
  • Learn about tension forces in different mechanical configurations
  • Explore the effects of varying mass and acceleration on force calculations
  • Investigate real-world applications of tension in railway systems
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of forces in train systems.
chrizzilla
A locomotive is pulling 15 freight cars, each of which is loaded with roughly the same weight. The mass of each can be taken to be 37,000 kg. If the train is accelerating at 0.72 m/s^2 on a level track, what is the tension in the coupling between the second and third cars? The car nearest the locomotive is counted as the first.
F=ma
I used F=ma to find that 37,000 kg * 0.72 m/s^2 = 26640 N. I know that this is the force for each traincar, I just don't know what to do with it.
Nevermind, I figured it out.
Since we are looking at the tension between the second and third cars, we only have to look at the force of 13 cars. You simply have to multiply the weight of one car by 13 and use the equation F=ma to calculate:
F = (13)(37,000kg)(.72m/s^2)
F= 346,320 N
  • · Replies 30 ·
