Adiabatic expansion in a steady flow question
The discussion revolves around solving an adiabatic expansion problem from the textbook "Mechanics and Thermodynamics of Propulsion" 2e, involving a perfect gas with a molecular weight of M=20 and a specific heat ratio of Y=1.2. The initial conditions include a pressure of 6 MPa, a temperature of 3000 K, and a velocity of 200 m/s, expanding to a final pressure of 0.101 MPa and a final temperature of 1800 K with negligible final velocity. The participant calculated the work done as 2494.29 kJ/kg, while the textbook answer is 3013 kJ/kg, indicating a potential error in the application of the first law of thermodynamics and the equations for work done in adiabatic processes.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the first law of thermodynamics
  • Knowledge of specific heat capacities (Cp and Cv)
  • Ability to perform calculations involving perfect gases
  • Review the derivation of the first law of thermodynamics for open systems
  • Study the relationships between Cp, Cv, and the specific heat ratio Y
  • Learn how to apply the equations for work done in adiabatic processes
  • Explore the implications of negligible velocity in energy calculations
Students and professionals in mechanical engineering, aerospace engineering, and thermodynamics who are solving problems related to adiabatic processes and energy transformations in gases.
wilkie610
I an working on a problem in the text "Mechanics and Thermodynamics of Propulsion" 2e. The problem states a perfect gas with molecular weight M=20 and a specific heat ratio of Y=1.2 expands adiabatically in steady flow from a pressure of 6MPa, a temperature of 3000K, and a velocity of 200 m/s to a final pressure of 0.101 MPa. If the final temperature is 1800K and the final velocity is negligible, what is the work done
I know that adiabatic means no heat in or out of the system so dq=0
Y=cp/cv and cp=cv+R
dq=de+dw
My attempt:
First i find R=8314.3/20=415.715
then i find cv by cv=R/(Y-1) cv=2078.58
thus dw= (-de) where de=cv(T2-T1)
my answer for the work done is 2494.29 kJ/kg however the books answer is 3013 Kj/kj
what am i doing wrong?
thanks for your help
dw = m*[(e2-e1)+(p2/rho2 - p1/rho1)+(v2^2 / 2 - v1^2 / 2)]
so, v2 = 0 , p/rho = RT(p=rho*R*T)
and Cp=Cv+R finally dw = CP(T2-T1) - v1^2 / 2
you do not think V1 ok?
This looks correct to me. Nice job of applying the open system version of the 1st law.
  • · Replies 24 ·
