Comparison Proof via axioms, almost done need hints for finish and proof read
The discussion focuses on proving the inequality \(0 \leq 2x^2 - 3xy + 2y^2\) using specific axioms of order and arithmetic. Participants utilize axioms such as transitivity and the properties of inequalities to manipulate the expression. Key cases are analyzed, including scenarios where \(x\) and \(y\) are equal to zero or one is positive while the other is negative. The conversation highlights the need for further assistance in completing the proof, particularly in handling the case where \(x \neq y\) and \(y \neq 0\).
  • Understanding of basic algebraic manipulation
  • Familiarity with axioms of order (transitivity, addition, multiplication)
  • Knowledge of inequalities and their properties
  • Experience with case analysis in mathematical proofs
  • Study the properties of inequalities in algebra
  • Learn about completing the square in quadratic expressions
  • Research the implications of the distributive property in proofs
  • Explore advanced techniques in mathematical proof strategies
Mathematics students, educators, and anyone interested in formal proofs and inequalities in algebra.
silvermane
1. The problem statement:
Prove that
[tex]0\leq2x^2 - 3xy + 2y^2[/tex]​
2. These are the axioms we are permitted to use:
01) Exactly one of these hold: a<b, a=b, or b<a
02) If a<b, and b<c, then a<c
03) If a<b, then a+c < b+c for every c
04) If a<b and 0<c, then ac<bc.
By axiom 03) we are permitted to add [tex]+-y^2[/tex] to both sides:
[tex]0 = -y^2 + y^2 \leq 2x^2 -3xy+2y^2-y^2+y^2[/tex]
[tex]0 \leq 2x^2 -3xy +y^2 + y^2[/tex]
Again, by axiom 03) we add [tex]+-x^2[/tex] to both sides:
[tex]0 = x^2 - x^2 \leq 2x^2 - 3xy +y^2 +y^2 + x^2 - x^2 = x^2 - 3xy + y^2 +y^2 + x^2[/tex]
By axiom 03) again, we add +-xy to both sides:
[tex]0 = xy - xy \leq 2x^2 - 3xy +y^2 +y^2 + x^2 - x^2 +xy - xy = x^2 - 3xy + y^2 +y^2 +xy +x^2[/tex]
Case 1: If x=y=0, then our expression is zero
Case 2: If x doesn't = y, and y=0, then we have [tex]0<x^2+x^2=2x^2[/tex]
Case 3: If x doesn't = y, and x=0, then we have [tex]0<y^2[/tex]
Case 4: If x doesn't = y, and [tex]y\neq0[/tex],
[tex]0 < (x-y)^2 < (x-y)^2 +x^2 +xy +y^2[/tex] ??
then I'm stuck and need help :rolleyes:
If anyone can help me figure out the last part, it would be greatly appreciated. I've worked very hard trying to figure it out, but that xy we would get could possibly be negative and I just need to prove that last part.
Thank you in advance for any hints/tips!
Case 1
[tex]x,y >0[/tex] This is trivial since everything is positive.
Case 2
[tex]x >0 ,y <0 \Rightarrow x>y[/tex]
[tex]-x^{2}< xy \Rightarrow 0< xy + x^{2}[/tex]
[tex](x-y)^{2} + y^{2}< (x-y)^{2} +x^{2} + xy +y^{2}[/tex]
Case 3
This is similar to case 2.
How come you can't use the distributive properties ?
Without them what does xy mean ? And how does it differ from yx ?
Assuming you could use axioms of multiplication and the distributive property you could divide by 2 and complete the square and the result falls into your hands.
[tex]x^2 - \frac{3}{2}xy + 2y^2 = (x- \frac{3}{2}y)^{2} + \frac{7}{16}y^{2}[/tex]
  • · Replies 18 ·
