Statistical mechanics - characteristics temperature of the HF molecule
The discussion revolves around the characteristic temperatures of the hydrogen fluoride (HF) molecule, utilizing spectroscopic data related to its vibrational frequency and moment of inertia. The context includes concepts from statistical mechanics, particularly in relation to molecular motion and energy levels.
  • Participants explore how to derive characteristic temperatures using energy relationships in statistical mechanics, questioning the starting point and relevant formulas. There is also a discussion on the contributions of vibrational and rotational motions to specific heat, with some participants attempting to clarify the degrees of freedom involved.
The discussion is active, with participants providing insights into the relationship between energy and temperature in statistical mechanics. There is an ongoing exploration of how different degrees of freedom contribute to specific heat, and while some guidance has been offered, participants are still questioning the implications of temperature on specific heat calculations.
Participants are navigating the complexities of the equipartition theorem and its application to diatomic gases, with specific reference to the temperature provided in the problem statement. There is an acknowledgment of the need to consider temperature dependence in the context of specific heat calculations.
Anabelle37
Spectroscopic data (rotational-vibrational lines) show that the hydrogen fluoride molecule has a vibrational frequency of 7.8x10^14 rad/sec and a moment of inertia of I=1.35x10^-47 kg.m^2. Find the relevant characteristic temperatures of the HF molecule.
I am completely lost on where to start and what formulas to use!
Please help!
Characteristic temperatures can be figured out easily like this:
the usual "energy unit" in statistical mechanics is k*T where k is Boltzmann's constant and T is the temperature.
Now different kind of motions have different "energy units" for example the energy for vibration is [tex]\hbar \omega[/tex].
So we shall obtain the characteristic temperature if we make this equal to the "statistical mechanics energy" : [tex]k\cdot T_v=\hbar \omega[/tex]
And from here you can express T_v.
Similarly for rotations, the energy of a quantum rotator is hbar^2/(2*I). and you can figure the characteristic temp. for rotations from this...
thank you heaps!
the following part says:
Assuming that HF is a diatomic gas, use the equipartition theorem to predict the specific heat of this gas (quoted as C_v/molecule/k) at T=520K
Won't there be a contribution to the specific heat from each of the vibrational and rotational parts which don't depend on temperature?
They do depend on temperature of course :)
Here what you have to do is figure out the different degrees of freedom. Since HF is a linear diatomic molecule it will have 2 rotational degrees of freedom (you can check this by looking on the molecule) then it will have 3 translational degrees of freedom (it can move in three directions in space) and finally it will have 1 vibrational degree of freedom (it can only vibrate with the atoms approaching each other, as if on a spring). But the vibrational part is tricky as one vibrational degree of freedom, means that there will be two square terms in the hamiltonian. These means that actually when using the equipartition theorem you will have to take this 2 times.
So totally there are 3+2+2*1=7 square terms in the hamiltonian. Hence the specific heat is ... and I will leave you to figure that out ;)
Ok thanks,
So the internal energy will be (7/2)*k*T so the specific heat will be (7/2)*k which doesn't depend on temperature so why have they given us T=520K??
