Thread Closed
wave functions
Share Thread Thread Tools
Sep18-10, 01:51 PM   #1
wave functions
2. Relevant equations
3. The attempt at a solution
[tex]
y_1(0,t)=y_2(0,t) \longrightarrow 1+\frac{B}{A}e^{2i \omega t} = \frac{C}{A}
[/tex]
[tex]
y_1_x(0,t)=y_2_x(0,t) \longrightarrow 1+\frac{B}{A}e^{2i \omega t} =\frac{k_2}{k_1} \frac{C}{A}
[/tex]
but I can not find an explicit expression for C/A and B/A expressed in v1 and v2 I can only find that k2/k1 =1. What am I doing wrong?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep18-10, 02:18 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
If k1=k2, the strings are identical, and you get no reflection.
Your wave function in region 1 looks a bit off. Typically, the second term is B e-i(k1+ωt). That still describes a wave moving to the left, but it lets the time dependence cancel out of the equations. Plus it'll result in equations you can actually solve.
Sep18-10, 02:23 PM   #3
Quote by vela View Post
You left out the x-dependence did you did this on purpose? Furthermore, the problem lies in the fact of the presence of the plus sign at [tex] \omega t[/tex]
But your conclusion is that there's a mistake in the question?
Sep19-10, 03:32 AM   #4
Recognitions:
wave functions
Sorry, that was a typo. There should be an x in there.
It appears there's a mistake in the question. You either get k1=k2, which means there should be no reflection, or C=0, which means there's no transmission.
Sep19-10, 05:29 AM   #5
I've send an e-mail to the instructor. Thanks for your help so far.
Sep20-10, 05:23 AM   #6
The instructor repied back there isn't any mistake in the exercise, it is possible! But I don't know how!
Sep20-10, 03:14 PM   #7
Recognitions:
Well, if you take the problem as given, the only consistent solution I see is B/A=0 and C/A=1, which in turn requires k1=k2. I've asked others to take a look at this thread. Perhaps they'll spot something we're both overlooking.
Sep20-10, 03:28 PM   #8
The instructor gave the answer if you take the real part of both equations you'll get a set of 2 equations which indeed lead to the right answer.
Sep20-10, 03:32 PM   #9
Recognitions:
Quote by dirk_mec1 View Post
[tex]
[/tex]
Here is my second opinion, for whatever it's worth. If C and A are constants, then the above expression says they are not because they are functions of time. The problem as stated implies that you may match boundary conditions at a specific time, but not at all times. To fix that, the correct form for the second term in y1(x,t) ought to be B*Exp[i(-kx-ωt)] which is still a wave traveling to the left. However, in this form, if you match boundary conditions at one time, you match them at all times because the e-iωt drop out.
Sep20-10, 03:39 PM   #10
Recognitions:
It may lead to the right intended answer, but the method isn't correct in my opinion. You can't just throw out the imaginary part of the equations because it's inconvenient.
Sep20-10, 03:42 PM   #11
Recognitions:
There has to be a typo. If [itex]y_1=Ae^{i(k_1x-\omega t)}+Be^{i(k_1x+\omega t)}[/itex] and [itex]y_2=Ce^{i(k_2x-\omega t)}[/itex] then the only way the two function can be equal at x=0 at all times (It wouldn't make sense for them to only be equal at one time unless the two strings were disconnected) is if [itex]Ae^{-i\omega t}+Be^{i\omega t}=Ce^{-i\omega t}[/itex] which tell you immediately B must be zero, and hence there is no reflected wave, and C=A.
If on the other hand [itex]y_1=Ae^{i(k_1x-\omega t)}+Be^{-i(k_1x+\omega t)}[/itex] , you don't have that problem, and there is a sensible solution.
Sep20-10, 08:22 PM   #12
Homework Helper 2012
Recognitions:
Quote by gabbagabbahey View Post
I think the same. Both the travelling and the reflected waves must have the same frequency, and omega is not the same as (-omega), although cos(wt) = cos(-wt).
ehild
Sep21-10, 05:24 AM   #13
He told us that the real part has a physical meaning therefore only the real part of the functions have to be considered. But I don't get what you mean by the typo. The imaginary part of the function is irrelevant, isn't it?
Sep21-10, 05:31 AM   #14
You forgot the second equations which is the derative.
Sep21-10, 10:03 AM   #15
Recognitions:
That only makes things worse. The only way to also satisfy that condition is if [itex]k_1=k_2[/itex].....which says that the wave must travel with the same speed in both strings!
Considering only the real part will give you the correct answer since [itex]\cos(-\omega t)=\cos(\omega t)[/itex], however it makes no sense to consider waves as the real part of complex wavefunctions if the imaginary parts of the complex wavefunctions you choose don't satisfy the same equations as the real parts. Doing so means you have to work exclusivly with the real parts, which defeats the entire purpose of using complex exponentials (they are often easier to work with than sines and cosines) in the first place.
If, on the other hand, you choose your complex waverfunction so that both imaginary and real parts can satisfy the boundary conditions, you are free to do all the calculations with the complex wavefunctions and then simply take the real part at the very end to get your physical result.
Sep21-10, 10:16 AM   #16
That sounds plausible. But what is the meaning of the complex part of the wave function? If I want to draw a picture I can only do so if I take the real part, agreed?
Thread Closed
Thread Tools
Similar Threads for: wave functions
Thread Forum Replies
Spherical Vector Wave Functions and Surface Green's Functions Advanced Physics Homework 0
Wave functions Advanced Physics Homework 3
wave functions Introductory Physics Homework 2
wave functions Advanced Physics Homework 3
wave functions Advanced Physics Homework 10
