| Thread Closed |
Thermodynaics, solving for minimum power to heat water |
Share Thread | Thread Tools |
| Sep19-10, 02:17 PM | #1 |
An electric hot water heater takes in cold water at 15.8°C and delivers hot water. The hot water has a constant temperature of 45.6°C, when the "hot" faucet is left open all the time and the volume flow rate is 5.0 multiplied by 10-6 m3/s. What is the minimum power rating of the hot water heater?
I really need help. I don't know how to connect Power and Thermal Energy. I know the individual formulas but can't connect the two. This is for WebAssign and is due within the hour. Please provide quick solution. Thank you very much. |
| Sep19-10, 02:19 PM | #2 |
Recognitions:
| Sep19-10, 02:21 PM | #3 |
Power is just the rate at which energy is converted, remember that.
| Sep19-10, 02:23 PM | #4 |
Q=cm(deltaT)
| Sep19-10, 02:28 PM | #5 |
Recognitions:
| Sep19-10, 02:41 PM | #6 |
wait i'm getting lost. sorry. so do i do Q=[cpv(deltaT)]/t
| Sep19-10, 02:46 PM | #7 |
so for my answer it would be Power= 4186(1.94)(5E-6)(45.6-15.8) where c=4186 and the density of water is 1.94
| Sep19-10, 02:46 PM | #8 |
is this correct?
| Sep19-10, 02:48 PM | #9 |
oh no wait. i got the density wrong. i have no idea what the density is since the temperature is different
| Sep19-10, 02:53 PM | #10 |
| Sep19-10, 03:11 PM | #11 |
0.591312 m^3?
| Sep19-10, 03:13 PM | #12 |
The average density of water should be 1g/ml, or 1g/cm^3,
whilst 1.94 is for lb/ft^3 if I recall right. |
| Sep19-10, 03:23 PM | #13 |
yeah. 1.94 is ft^3
so in the equation i would actually plug in .001kg/m^3 since were using kg not g |
| Sep19-10, 03:24 PM | #14 |
Your unit conversion is wrong, if you were to use m^3 you should get something else.
| Sep19-10, 03:28 PM | #15 |
Power= 4186(1000)(5E-6)(45.6-15.8)
so the conversion is 1000kg/m^3 is the above formula correct? |
| Sep19-10, 03:31 PM | #16 |
It should be right, yes.
| Sep19-10, 03:35 PM | #17 |
thank you so much. i actually learned something for once.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thermodynaics, solving for minimum power to heat water
| [SOLVED] Quantity of Heat/Specific Heat Water+Iron | Introductory Physics Homework | 3 | ||
| 12v minimum power - help please | Electrical Engineering | 4 | ||
| Variably Solving for Minimum Tangential Speed | Introductory Physics Homework | 1 | ||
| Specific heat capacity, latent heat => ice water steam mixture | Introductory Physics Homework | 1 | ||
| Minimum power | Introductory Physics Homework | 2 | ||
