Contradiction/breach 2nd law? Simply with carnot engine + negative temperature
The discussion revolves around the implications of negative temperatures in thermodynamics, particularly in relation to the second law of thermodynamics and the operation of a Carnot engine. Participants explore the theoretical framework and potential contradictions that arise when considering heat flow between systems at negative temperatures.
  • Some participants assert that negative temperatures can exist and are defined as being "hotter" than any positive temperature, challenging conventional thermodynamic principles.
  • Others argue that negative temperatures cannot exist on the Kelvin scale, emphasizing that absolute zero is the lowest possible temperature.
  • A participant questions how heat can flow from a lower temperature (negative) to a higher temperature (positive), suggesting this contradicts established thermodynamic behavior.
  • Some participants propose that the equations governing reversible heat engines may still apply to systems with negative temperatures, but express uncertainty about the validity of these applications.
  • There is a suggestion that the behavior of ideal paramagnets at negative temperatures may lead to scenarios where work is delivered despite the apparent violation of the second law.
  • One participant introduces a thought experiment to illustrate a potential breach of the Kelvin-Planck statement, raising questions about the nature of work and heat transfer in these systems.
Participants do not reach a consensus on the validity of negative temperatures or their implications for the second law of thermodynamics. Multiple competing views remain, with some defending the concept of negative temperatures while others challenge its applicability and implications.
Limitations include the unclear definitions of negative temperatures and their relationship to energy states, as well as unresolved mathematical steps in applying traditional thermodynamic equations to these scenarios.
nonequilibrium
Hello,
For a reversible heat engine between temperatures [tex]T_1[/tex] and [tex]T_2[/tex], the ratio of heat going in and out the engine is [tex]\frac{Q_1}{Q_2} = \frac{T_1}{T_2}[/tex] (second law).
Say [tex]T_1 = 200 K[/tex] and [tex]T_2 = 273 K[/tex], then heat goes from 2 to 1 and as we can see, the ratio of heat that goes in the engine is indeed bigger than what comes out ( = logical, due to delivery of work).
Take two ideal paramagnets, each at a negative temperature (note: negative temperature > positive temperature; the scale goes [tex]0 \to \infty \to - \infty \to 0[/tex]).
Now say [tex]T_1 = -200 K[/tex] and [tex]T_2 = -273 K[/tex], then heat will go from 1 to 2 (Because the entropy of paramagnetic reservoir 1 will raise more than the drop in that of paramagnetic reservoir 2). The ratio of heat going in and out hasn't changed due to the minus cancelling in top and bottom. This says that the heat going in from 1 into the engine is less than the heat deposited from the engine into 2.
What's the explanation?
Science news on Phys.org
You cannot have a negative temperature on the Kelvin scale. 0 is absolute zero, you cannot get any colder than that.
:( You missed my point completely, did you even read my post? I said negative temperature is even hotter than any positive temperature!
What does that even mean? How can a negative temperature be hotter than a positive temp?
Abstract math is not physics
That if it's placed in contact with any system with a positive temperature, heat will flow from the negative to the positive system.
EDIT: (to pythagorean) What do you mean? With what part do you not agree? Please don't interpret me as somebody who is saying "the 2nd law is false"; of course not. I'm just trying to interpret the above. The two two things that seem contradictory to me: 1) the ratio of heat directly derived from the 2nd law; 2) heat flow for idealized paramagnets.
Kelvin is bound between 0 and a finite number because it's based on energy. You can't have negative energy and you can't have infinite energy.
This is the faulty application of abstract math that I'm referring to:
Why would heat flow from a lower temperature to a higher temperature? Or does this go back to saying that the negative temperature has more heat than the positive temperature?
Please excuse the ignorance of the previous posters. They really should read up some concepts beyond the very basics before they complain.
I haven't thought too much, but my first guess is that you are completely right, but there is no problem. In one case work goes in for a reversible operation and in the other case work goes out. Is that a problem?
mr. vodka said:
Hello,
Negative temperatures are only defined for systems with a limited number of energy states. I am not sure that the derivation for the equation of the heat engine is valid for such a system. I would think you would need to work this with statistical mechanics.
I think the equation still works for reversible processes in any system. What about my proposal that indeed there is a difference, but it's not a problem?
I suspect (just a guess really) that is correct, but I would have to actually work through the derivation of the heat engine for a negative temperature system before I would feel comfortable making that assertion.
Hello, thank you for the replies.
Gerenuk, I'm not sure how it would not be a problem? If [tex]T_1 = -200K[/tex] and [tex]T_2 = -273K[/tex], then heat will flow (if allowed...) spontaneously from system 1 to system 2, we all agree on that. This means I can put in an engine with system 1 acting as the hot reservoir and 2 as the cold reservoir, where [tex]W > 0[/tex]. Obviously the heat coming out of 1 must thus be greater than the heat going into 2, if work is delivered, yet the reversible equation [tex]\Delta S_{universe} = - \frac{Q_1}{T_1} + \frac{Q_2}{T_2} = 0[/tex] implies this is not the case (if you're wondering about the signs: the first term in its totality presents the entropy GAIN in the first system, so since the temperature is negative, I had to add a minus [N.B.: all [tex]Q[/tex] symbols are taken as absolute values]; reverse the situation for system 2).
DaleSpam, fair point! So you can't actually make them reservoirs without destroying their weird behavior, but okay, let's imagine the two pseudo-reservoirs really big and only a small engine in between. The equation [tex]\Delta S_{universe} = - \frac{Q_1}{T_1} + \frac{Q_2}{T_2} = 0[/tex] won't be exact anymore, but we can approach zero as close as we want, and then even for finite reservoirs we'll get the weird situation where the heat deposited is greater than the heat absorped, although work was delivered...
Really weird situation, cause it's such a simple set-up, but I can't pinpoint where it goes wrong...
Why should work be delivered? The only constraint is that it is reversible. But maybe this transfer actually requires heat?
Just a random thought... not sure.
Okay, let's do the following thought experiment:
Q_h is the heat going from 1 into the engine, Q_c is the heat going from the engine into 2. Now let's presume the engine USES work W as to fix our anomaly. Then Q_h + W = Q_c. Now stop the engine. Call the state of the universe we have now A. Now reverse the engine: now we get out W and Q_c leaves 2 and Q_h goes into 1, okay. Now as we know: heat can spontaneously flow from 1 to 2, so let the Q_h flow back spontaneously into 2. Stop. Call this state B. Now if you've followed closely, the net result of going from A to B: heat has been taken out of 2 and work has been delivered without any other effect in the universe.
The Kelvin-Planck statement says "It is impossible to convert heat completely into work in a cyclic process." We have just breached this in our thought experiment, thus W must be going out instead of in.
Or the summary of this post for the lazy ones: if it costs work rather than gives work, we'd directly be breaching the kelvin-planck version of the 2nd law.
How do you achieve a negative temperature (-K)?
The results from putting a negative Kelvin figure into this equation are no different to a person accidentally putting the Celsius value in (when negative). Putting the Celsius value into this equation doesn't work.
Just because you can put other values in (particularly Celsius as they can be equal to the Kelvin Value - 0C = 273K etc and this is a common mistake) doesn't make the result that comes out correct.
You can prove any law of physics wrong if you invent values to go into it, but unless you can prove the existence of negative temperatures (below 0K - or negative energy), I think you're breaching PF guidelines.
Or am I just totally missing the point here?
A negative temperature in statistical mechanics is a description of certain systems (not ideal gas) where there are a limited number of states. In these systems it is possible to get situations where adding energy decreases entropy. By the definition of temperature such a system has a negative temperature.
http://www.phys.ncku.edu.tw/mirrors/physicsfaq/ParticleAndNuclear/neg_temperature.html
jarednjames: Indeed you're missing the point, as you say yourself, but I don't mean that impolitely: I'd also be very skeptical if I hadn't heard of statistical mechanics before. The main difference between the temperature you're used to is that this temperature's no longer a degree for kinetic energy, but something more general (still dependent on the concept of energy). The important thing is that the equation I use is not dependent on the kinetic energy temperature and should also be applicable to the general situation, or at least I thought so. The conclusion seems to be that [tex]\Delta S = \int \frac{dQ_{rev}}{T}[/tex] does not work in general? :o
So does this have a basis in real life? Is it useful or just some piece of maths that shows A but we can only achieve B due to the laws of physics?
"By the definition of temperature such a system has a negative temperature."
Does the temperature actually drop below 0K or is it purely showing it as a negative temperature (in reality, the temperature is +K (any positive temperature) but due to the maths it comes out as negative)?
I don't know what you mean by this. What is an "actual" temperature as opposed to the temperature you get "due to the maths"? Physical quantities have some definition, I don't know what an "actual" physical quantity would be in the absence or contradiction of its definition, especially not one so abstract as temperature.
Well I'm talking about an ideal paramagnet, which doesn't exist, but that's like an ideal gas doesn't exist: the fact it doesn't exist doesn't make it useless, it's just an easy way to understand the basics. It does have a physical significance and should thus be taken seriously, IMO. Anyway,
(ignore the names on it, just took the right shape from google) Say the energy is the x-axis and the entropy is the y-axis. Then this is the graph for a paramagnet. As you can see, if you keep adding energy, eventually the entropy will go down (this can be proven, this is just the result). If [tex]\beta[/tex] is the derivative of the graph at a certain point, then according to the established relation [tex]\beta = 1/kT[/tex] we get that the right portion of the graph represents a negative temperature. If you think about it, using this graph, you'll understand why a negative temperature is actually hotter than any positive temperature. If you want more exact info, I direct you to a textbook on statistical mechanics :) very interesting
Anybody any ideas ? :/
EDIT: I PM'd jared to reply to his post below; didn't answer here cause I don't want to get too much off topic
I mean, does the temperature drop below 0K? Bare in mind no one can get to 0K, let alone below.
When I say the 'maths showing it as negative', I mean does the temperature show as negative in the equation but in real life there is always a positive temperature. If I have understood the graph above, the right side of the graph shows a negative temperature. But the actual temperature of the system is always positive. I can't really put it into words what I'm thinking.
I'll chalk this up to me not knowing what statistical mechanics is.
As mr. vodka already mentioned, the temperature of systems with a negative temperature is higher than that of any system with a positive temperature. The discovery of such systems did lead to a slight modification of the second law of thermodynamics. Google "Kelvin-Planck-Ramsey statement".
Oooooh! I got a googlewhack! Searching for the exact phrase "Kelvin-Planck-Ramsey statement" yields exactly one hit (it's going to be two in short order when Google finds this thread). Getting rid of the quotes yields a lot more hits.
I thought it couldn't have quotes to be a googlewhack?
EDIT: and only two words after a quick definition check.
Anyway, I think I get what you mean now.
Oh, thanks DH. Heh, only one google hit, here we go:
No process exists whereby the only effect is either to convert heat from a single thermal reservoir at a positive temperature completely into work on a system, or to transform work on a system completely into heat and to deliver it to a single thermal reservoir at a negative temperature [Kelvin-Planck-Ramsey statement].
Hmmm... :P Well that does solve the problem, but it seemse quite ad hoc. I'm not even sure if it is non-contradictory, must think on it. Interesting.
EDIT: just noticed the posts above ;) And DH google already listed your post as 2nd lol
There is that.
Kelvin-Planck-Ramsey is the first word, statement the second.
I was just finishing the definition off, didn't mean you were wrong.
Still not bad though, and yes, you are now first on Google according to my results.
A negative temperature system is hot, not cold. Remember, when we have two systems which are exchanging energy through thermal contact the energy will be divided up among the two systems in the manner which maximizes the total entropy. If you have one system that has monotonically increasing entropy and one system that has some peak entropy and if your system with peak entropy has more energy than its peak entropy state then entropy is always increased by transferring that energy to the other system regardless of how hot the other system is. This means that it has a higher temperature than infinity. So thermal energy transfer will always be from a system of negative temperature to a system of positive temperature.
  • · Replies 20 ·
15K
  • · Replies 17 ·
  • · Replies 26 ·
