Firefighter's Water Stream Strike Height Calculation
The discussion focuses on calculating the height at which a firefighter's water stream strikes a building, given specific parameters: a distance of 44.0 meters from the building, an angle of 31.2° above the horizontal, and an initial speed of 40.0 m/s. The relevant equations include the horizontal and vertical components of velocity, v(x) = v * cos(31.2°) and v(y) = v * sin(31.2°), respectively. The range formula R = (v * sin²(31.2°)) / g is also utilized, where g is the acceleration due to gravity (9.81 m/s²). The key takeaway is that the height of the water stream upon impact can be calculated without needing the height of the building itself.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of basic physics equations related to motion
  • Ability to perform calculations involving gravitational acceleration
  • Study projectile motion in detail, focusing on horizontal and vertical components
  • Learn how to apply trigonometric functions in physics problems
  • Explore the derivation and application of the range formula in projectile motion
  • Practice similar problems involving angles and initial velocities
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of projectile motion, particularly in real-world applications like firefighting techniques.
jitto92
A firefighter, 44.0 m away from a burning building, directs a stream of water from a ground level fire hose at an angle of 31.2° above the horizontal. If the speed of the stream as it leaves the hose is 40.0 m/s, at what height will the stream of water strike the building?
v=40.0m/s
v(x)=vcos31.2
v(y)=vsin31.2
g=9.81
R=(vsin^2(31.2))/g
x(t)=vcos(31.2)
I have tried breaking it down to x and y components but it doesn't make sense if the height of the building and its distance from the firefighter is not given !
(1) The distance from the firefighter is given.
(2) You don't need the height of the building, just the height of the stream as it hits the building.
  • · Replies 18 ·
