Is finding the intersection of two lines in R4 using the same method as in R3?
  • Context: Undergrad
  • Thread starter Thread starter theRukus
    Intersection Lines
Finding the intersection of two lines in R4 follows the same method as in R3, where the lines are set equal to each other, resulting in four equations with two unknowns, s and t. The equations are derived from the parametric representations of the lines in four dimensions. However, unlike R3, where lines are typically skew, in R4, the intersection of two lines is a rare occurrence, making it a special case. The determinant of the coefficient matrix must be non-zero for a unique solution to exist.
  • Understanding of parametric equations in multiple dimensions
  • Knowledge of solving systems of linear equations
  • Familiarity with determinants and their role in linear algebra
  • Basic concepts of vector spaces and dimensions
  • Study the properties of parametric equations in R4
  • Learn about determinants and their significance in linear systems
  • Explore the concept of skew lines in three and four dimensions
  • Investigate the geometric interpretation of intersections in higher dimensions
Mathematicians, physics students, and anyone interested in higher-dimensional geometry and linear algebra concepts.
theRukus
To find the intersection of two lines in R3, you set the lines equal, right?
[a,b,c] + d[e,f,g] = [h,i,j] + k[l,m,n]
Then split these into three equations,
1. a + d(e) = h + k(l)
2. b + d(f) = i + k(m)
3. c + d(g) = j + k(n)
And solve for k and d, correct?
If k and d are consistent, then these values are used to find the point of intersection.
My question is: Is this same method used in R4, with two lines of 4 dimensions?
Probably you could get some help after explaining your notation...
Yes, it is exactly the same. You would have one line given by, say,
[tex]\begin{pmatrix}x_1 \\ x_2 \\ x_3 \\ x_4\end{pmatrix}= \begin{pmatrix}a_1t+ b_1 \\ a_2t+ b_2 \\ a_3t+ b_3 \\ a_4t+ b_4\end{pmatrix}[/tex]
and the other by
[tex]\begin{pmatrix}x_1 \\ x_2 \\ x_3 \\ x_4\end{pmatrix}= \begin{pmatrix}c_1s+ d_1 \\ c_2s+ d_2 \\ c_3s+ d_3 \\ c_4s+ d_4\end{pmatrix}[/tex]
then you would set them equal getting 4 equations in the two unknown values s and t:
[itex]a_1t+ b_1= c_1s+ d_1[/itex]
[itex]a_2t+ b_2= c_2s+ d_2[/itex]
[itex]a_3t+ b_3= c_3s+ d_3[/itex]
[itex]a_4t+ b_4= c_4s+ d_4[/itex]
Of course, it would be unlikely for 2 numbers to satisfy all 4 equations!
In the plane, the "typical" behavior is for lines to intersect- the only non-intersecting lines are parallel lines, a very unusual situation. And, in two dimensions, we are solving two equations in two unknowns- there would not be a unique solution only if the determinant of the coefficient matrix were 0.
In three dimensions, the "typical" behavior is for lines to be skew- not intersecting. In order to be able to solve three equations for two unknown values, the equations must NOT be independent.
And the situation is worse in four dimensions. Two lines intersecting is a very special situation indeed.
  • · Replies 17 ·
  • · Replies 17 ·
