Calculating Time and Distance for Two Soccer Players Colliding from Rest
  • Thread starter Thread starter BlackMamba
    Time
The problem involves two soccer players starting from rest and running towards each other from a distance of 51 meters. The first player has an acceleration of 0.50 m/s², while the second player has an acceleration of 0.30 m/s². The questions posed are about calculating the time until they collide and the distance covered by the first player at the moment of collision.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate the time until collision but expresses confusion about how to approach the problem. Some participants suggest using kinematic equations to find the distance and time, while others question how to apply these equations to both players. There is discussion about the nature of velocity and whether it is relevant to the problem.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning assumptions about velocity and acceleration. Some guidance has been offered regarding the use of equations for distance and time, but there is no explicit consensus on the best approach yet.
Participants are considering the implications of the players' accelerations and the initial conditions of the problem. There is a focus on understanding how to set up the equations correctly to account for both players' movements.
BlackMamba
I'm am yet again confused.
I have a problem which has two soccer players starting from rest, 51m apart. They run directly toward each other. The first players acceleration is 0.50 m/s^2. The second player's accelration is 0.30m/s^2.
(a) How much time passes before they collide?
(b) At the instant they collide, how far has the first player run?
Ok so here's what I know:
Both players initial velocity is 0m/s.
Both players initial distance is 51m.
Player one has an acceleration of 0.50m/s^2.
Player two has an acceleration of 0.30m/s^2.
So I calculated the velocity of both players. Now calculating the time, is where I begin to loose focus. Do I find each players total time? If so, how does that tell me when they collide?
Thanks for any help
Try using this
D = Vi + (AT^2)/2 and
Vf = Vi + AT
D = distance, meters
Vi = initial velocity, meters/sec
T = time in seconds
A = acceleration, meters/sec
Vf = final velocity, m /s
Vi, as you noted is 0
So, 51 meters = A1T^2/2 + A2^T2/2
where A1 is first runners acceleration and A2 is second runners acceleration
Im not sure I understand. The first two equations you gave, I know will give me the distance and final velocity. However do I apply those first two equations to both players?
And I think I understand that the last equation will give me the time. Is that correct? However I'm having a hard time understanding what it actually reads.
How did you calculate the velocity ? Like I've asked you before, the velocity keeps changing, so which velocity are you talking about ?
Picture this scene in your head. Two players on the field... you are observing with a stopwatch...the instant they start, you start the timer...they start very slowly, but keep getting faster...the instant they collide you stop the timer. So you see; there is only one time...not a different time for each player.
The important thing to notice is that the sum of the two distances run, gives the total distnce = 51 m. Write the equations for distance of each runner in terms of time, initial velocity (=0) and acceleration. Then add these two equations and set the sum to 51. This will give you the equation for t that Chronos describes in his last paragraph.
My original thinking was to find the final velocity. But the final velocity would actually be 0, wouldn't it? As in when they collide they would actually be no longer be moving. Am I thinking this right now? So my equations for the final velocity are useless.
I did draw a picture on my paper. Trying to picture it.
Ok, I will go and work on what you have told me. I'm sure I will be back shortly though. LOL
Thank you.
Tell me Black Mamba when you're driving a car and suddenly you hit a tree, is your final speed 0?, think about it.
Forget about the final velocity. The conditions described (their accelerations) change after impact. We are only concerned with what happens up to instant of impact, as the given conditions apply only during this time.
If you don't knock the tree over, yes it is !
Cyclovenom, I don't mean to criticize your post, but I think it best that BlackMamba try first to understand what's happening in the given problem.
  • · Replies 38 ·
  • · Replies 22 ·
