Help with 2 simple probability probs
  • Thread starter Thread starter Juntao
    Probability
The discussion revolves around two probability problems. The first problem involves calculating the number of different meal combinations from a restaurant's menu, considering three courses. The second problem concerns the programming of garage door openers in a condominium, specifically whether the number of button combinations is sufficient for the number of families.
  • Participants explore various ways to calculate meal combinations for the first problem, questioning how to correctly account for the number of courses. For the second problem, there is discussion about the implications of button combinations and whether the order of button presses matters.
Several participants have provided different approaches to the problems, with some suggesting formulas and others questioning the assumptions made. There is a mix of interpretations regarding the calculations needed for both problems, indicating an ongoing exploration of the concepts involved.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is also a note about excluding certain cases in the second problem, which adds complexity to the discussion.
Juntao
help with 2 "simple" probability probs
Ok, I'm having a hard time with probability.
First problem.
A restaurant offers a choice of 4 appetizers, 14 entrees, 6 desserts, and 5 beverages. How many different meals are possible if a diner intends to order only three courses? (consider the beverage to be a course)
Maybe I'm making this problem harder than it is. I want to do 4*14*6*5 = answer, but that would only be for a 4 course meal, not a three course meal...right?
Second problem
Residents of a condominium have an automatic garage opener that has a row of 8 buttons. Each garage door has been programmed to respond to a particular set of buttons being pushed. If the condominium has 250 families, can residents be assured that no two garage doors will open on the same signal? If so, how many additional families can be aded before the 8-button code becomes inadequate? *Note* The order in which the buttons are pushed is irrelevant.
I was thinking maybe the answer would be like 250^8, but that doesn't seem right to me. Since the order doesn't matter, 8 buttons such as 12345678 would be same thing as 87654321.
So I was thinking maybe answer was 8! ?
First problem: You need to consider all the ways it is possible to get 3 courses.
Second problem: A button will either be depressed or it will not. That gives two choices for each of 8 buttons. Also note that the case with no buttons pressed should be excluded.
1st problem:
4*14*6 + 14*6*5 + 4*14*5
2nd problem:
2^8=256
Actually, Tile was right, 00000000 should be excluded, so it should be
256-1=255
Simply consider it's an 8-digit binary number.
jxiemail said:
1st problem:
It's almost midnight where I'm from and I am feeling very sleepy. I can't think straight but this doesn't look right. The way I see it there are 4 ways of choosing 3 beverages from 4 beverages. So the answer is = 4*14*6*5*4.
n(ABC+ABD+ACD+BCD)
= n(ABC)+n(ABD)+n(ACD)+n(BCD)
=n(A)*n(B)*n(C)+n(A)*n(B)*n(D)+n(A)*n(C)*n(D)+n(B)*n(C)*n(D)
-- AI
TenaliRaman said:
n(ABC+ABD+ACD+BCD)
-- AI
That looks like a handful. :bugeye: Not entirely elegant, is it? But it is good to memorise this just in case you are not able to solve it logically in an exam.
No need to memorize ... it comes directly from a theorem called as the addition theorem ... its more important to understand what i did in my first step rather what i have done in the following steps ... because they are derived from the theorem itself ...
-- AI
P.S -> I put the answers in the hope that it will encourage the enquiring mind as to what and how those steps came ... instead of simply rote learning them ...
  • Sticky
73K
  • Sticky
  • · Replies 0 ·
24K
  • Sticky
  • · Replies 0 ·
19K
  • Sticky
27K
  • Sticky
  • · Replies 0 ·
22K
  • Sticky
30K
