Tube Buoyancy Question: How Much Force Is Needed?
  • Context: Undergrad
  • Thread starter Thread starter jackrabbit
    Buoyancy Tube
The discussion revolves around the forces required to pull a hollow tube, which is partially submerged in water, completely into a container. Participants explore the concepts of buoyancy, water pressure, and the net forces acting on the tube in this scenario.
  • Exploratory, Technical explanation, Debate/contested
  • One participant proposes that the force needed to pull the tube could be 10 pounds, while others suggest it might be 10 pounds plus water pressure.
  • Another participant expresses uncertainty, considering that the buoyancy of the top half of the tube might reduce the required force, but is unsure how to quantify this effect.
  • A later reply asserts that the buoyant force acts as a net force due to the surrounding fluid pressure, indicating that the net force from the fluid could push down on the tube.
Participants express differing views on the exact force required, with no consensus reached on whether it is solely 10 pounds, 10 pounds plus water pressure, or a different amount due to buoyancy effects.
Participants have not fully resolved the implications of buoyancy on the force required, and there are assumptions about the absence of friction and the nature of the water pressure acting on the tube.
jackrabbit
Suppose you had a hollow tube, closed at both ends. The tube weighs 10 pounds and would float in water.
Suppose also there is an empty container with a hole at the bottom. The tube is stuck through the hole so that half of it is in the tank and half is sticking out the bottom. Assume a water tight fit between the tube and the hole.
Now, fill the tank with water so that the water surface is a foot or two above the top of the tube.
How much force is necessary to pull the tube through the water and completely into the container? (Assume for the sake of argument that there is no friction between the tube and the sides of the hole). Is it (a) 10 pounds; (b) 10 pounds plus water pressure; (c) something less than 10 pounds because the top half of the tube is buoyant even though the bottom half is sticking out the bottom of the hole; or (c) something else?
What do you think?
I don't know. My gut says it should be the full 10 pounds plus water pressure, but I am having trouble figuring out why it wouldn't be less given the buoyancy of the top half (perhaps less than 10 pounds for the tube but then add water pressure?).
Your gut is correct. Buoyant force is the net force on the body due to the pressure of the surrounding fluid. Under 'normal' circumstances, the body is completely surrounded by fluid or is floating, thus the buoyant force is upward. But in a case like you describe, the net force from the fluid actually pushes down on the object.
27K
  • · Replies 48 ·
12K
