Can an Opamp be Used to Create a Voltage to Voltage Converter?
  • Thread starter Thread starter tabish fawad
    Converter Voltage
The discussion centers around the feasibility of using an operational amplifier (opamp) to create a voltage-to-voltage converter. Participants explore various configurations and components, including transistors and resistors, while considering practical applications and theoretical implications.
  • One participant questions whether a voltage-to-voltage converter can be physically formed, referencing the existing knowledge of transistors as voltage-to-current converters.
  • Another suggests that adding a resistor could facilitate the conversion, pointing to a common emitter configuration as a starting point.
  • A participant clarifies that a transistor functions as a current-to-current amplifier, emphasizing that circuit configuration influences its behavior regarding voltage and current.
  • There is acknowledgment of disagreement regarding the nature of transistors, with one participant noting that the circuit's configuration determines its function.
  • One participant proposes that a voltage-to-voltage converter could be achieved by adding a capacitor at the output, raising questions about its effectiveness with a DC source.
  • A participant discusses the importance of both current and voltage in the operation of a transistor, highlighting the need for careful design in applications like transformers.
  • Another participant explains that if the output voltage is less than the input, a simple resistive voltage divider can be used, while a voltage regulator is necessary for maintaining a constant output under varying conditions.
  • It is suggested that an opamp could be used to achieve an output greater than the input voltage, depending on the resistor ratio, but with the caveat of not exceeding the supply voltage.
Participants express differing views on the functionality and configuration of voltage-to-voltage converters, with no consensus reached on the best approach or the role of various components.
Some claims rely on specific circuit configurations and assumptions about component behavior, which may not be universally applicable. The discussion includes references to both theoretical concepts and practical applications, indicating a range of interpretations.
tabish fawad
Our Transistor is a Voltage to Current converter can we form a Voltage to Voltage converter too physically or not??
can someone help me in this matter pleasez
Actually a transistor is a current to current amplifier.
For the record, I agree with post #3 but there has been a lot of discussion/disagreement on this. Quite possibly on this forum. How a transistor circuit is configured determines what the circuit is as a whole concerning voltage and current, etc.
guys i mean that we can make a voltage to voltage converter by just adding some resistor,,can it be possible in daily life that we input voltage and in return we get voltage too.if so then wat in case of adding a capacitor at the output?,in that case we are also getting voltage at the output but for dc source capacitor will open and circuit will nt work.
This sounds like a discussion in semantics...a transister requires current AND voltage at the input and produces an output with a current AND a voltage...the configuration, emitter,base, collector, ground, etc depends on what you are trying to accomplish...that is, the application.
As an example, you can call a transformer a voltage conversion device, because that's usually wheat we are interested in accomplishing, but it involves the flow of current as well and both must be taken into account in design. If you want to make a step up transformer, for example, say 120 volts in and 240 volts out, too small a wire size and improper resistance in either the primary or secondary will cause the wire to overheat and maybe a fire...
http://en.wikipedia.org/wiki/Electrical_transformer
If your output voltage is to be less than your input voltage it is very easy to convert the input voltage to the output voltage. If the output voltage is to be a percentage of the input voltage and the load will be high impedance then a simple resistive voltage divider will work. If you want a constant voltage out with a varying input voltage or a varying load then you can use a voltage regulator.
However, if you want your output voltage to be higher than your input voltage, then the input must be converted to AC, transformed to a higher voltage, rectified and filtered to remove the remaining AC. This may be the purpose of the capacitor.
If you want an output which is greater than the input voltage, you could also use an opamp.
Depending on the ratio of a pair of resistors, you can have an output which is directly related to the input by the same ratio as the ratio of the resistors, as long as you don't need the output to be greater than the supply voltage.
  • · Replies 17 ·
  • · Replies 32 ·
