Closed, bounded but not compact
The problem involves proving that the metric space X = [0, ∞) is closed and bounded but not compact, using the metric |e^(-x) - e^(-y)|. The discussion centers around the definitions and properties of compactness in metric spaces.
  • Participants discuss various methods to demonstrate the non-compactness of the space, including the use of Cauchy sequences and the concept of open covers. Some suggest finding a specific sequence that illustrates the lack of a finite subcover.
The discussion is ongoing, with participants exploring different approaches to the problem. Some have provided guidance on using subsequences and open covers, while others express uncertainty about the methods and seek clarification.
There is a mention of the need to verify whether certain sets are open in the given metric, which may affect the approach to proving non-compactness.
bender2
let |e-x-e-y| be a metric, x,y over R.
let X=[0,infinity) be a metric space.
prove that X is closed, bounded but not compact.
there is no problem for me to show that X is closed and bounded. but how do I prove it's not compact?
I assume it must be done with the use of Cauchy sequence. if xn is Cauchy but it's not convergent then X is not complete and then it's not compact. but how do I right it down in algebraical form?
thanks in advance.
What about trying to find a sequence of points each of which has its own open cover so that no finite subcover exists?
i'm afraid i don't know how to do it. can you show me please?
and is the way with Cauchy sequence correct?
You can use the form of compactness with regard to subsequences. For every sequence x_{n} in the metric space then there is a convergent subsequence.
Normally one would prove that [itex][0, \infty)[/itex], with the usual metric, is not compact, directly from the definition, "every open cover contains a finite subcover", by looking at the "open cover" [itex]U_n= [0, n)[/itex]. Are those sets open in this metric?
I think Halls means [0,n).
Yes, I did. Thanks. I will edit it.
