LaTex is supposedly very good in producing lab reports
  • Context: LaTeX
  • Thread starter Thread starter JamesJames
    Lab Latex
The discussion revolves around the use of LaTeX for producing lab reports, including inquiries about downloading the software, installation issues, and alternative applications. Participants share their experiences and seek advice on using LaTeX effectively, particularly for those with limited programming knowledge.
  • Homework-related
  • James expresses interest in LaTeX for lab reports but struggles to find a free download and questions its ease of use given his limited programming background.
  • Some participants suggest specific resources for downloading LaTeX, such as MikTeX for Windows and Kile for Linux.
  • Warren mentions that LaTeX has a steep learning curve and encourages James to ask questions if he encounters difficulties.
  • There are inquiries about converting LaTeX files to image formats, with suggestions that dvi viewers and specific programs can accomplish this task.
  • James seeks clarification on how to open and use LaTeX after installing MikTeX, expressing confusion about the necessary packages and file types.
  • Warren provides instructions on using the command line to compile LaTeX files into PDFs, while also addressing James's questions about text editors and file management.
  • Participants discuss the possibility of using GUI applications for LaTeX, with varying opinions on their availability and ease of use compared to command-line operations.
  • James expresses frustration with the installation and usage process, contemplating whether to seek a CD version of the software.
  • Some participants suggest using MS Word's equation editor as an alternative for inserting mathematical content into reports, although James encounters issues with accessing this feature.
The discussion reflects a mix of agreement on the usefulness of LaTeX and disagreement on the best methods for installation and usage. Participants have differing opinions on the necessity and effectiveness of GUI applications versus command-line usage, and there is no consensus on the best approach for beginners.
Participants express varying levels of familiarity with LaTeX and command-line interfaces, leading to different assumptions about the ease of use and installation processes. Some technical details remain unresolved, such as specific installation steps and the functionality of various LaTeX packages.
This discussion may be useful for students or individuals interested in using LaTeX for document preparation, particularly those with limited programming experience seeking guidance on installation and usage.
JamesJames
I have heard of something called LaTex which is supposedly very good in producing lab reports etc. I was told that it is available for free somewhere on the internet but after hours of looking I have been unsuccessful in finding it. I would like to know where I could download this free version of the software and how easy is it to use LaTex since I know very little about programming i.e. elementary Fortran and Visual Basic.
thanks,James
James,
Which OS are you using? Windows? If so, download a copy of MikTeX. Bear in mind that these programs have a fairly steep learning curve, so feel free to ask questions. You probably will have a hard time figuring it all out on your own.
- Warren
www.tug.org has a link to most of the commercial and non-commercial versions along with many packages to use as templates. I would recommend Kile if you are using Linux, best LateX Gui I have seen.
I; ve downloaded the miktex setup wizard and it has installed miktex on the system(Windows)
Hi
This is a totally different question regarding an application of LaTeX, but I thought I'd post it here...
Is anyone aware of a program which can convert small latex files to gif/jpg/png/other web-acceptable image formats? Actually somewhat like PF's LaTeX backend?
Thanks and cheers
vivek
maverick280857 said:
Hi
Thanks and cheers
vivek
Most any dvi viewer should do that. There's also dvi2ps and dvi2pdf on the linux side.
I have downloaded the miktex program as said above but how do I open latex? Do I need to install that package? There are about 5 different packages that start with latex. Do I install all? All I want is to be able to use it to prepare some reports. Any help would be really great since I am new to this .
You'll probably need to run latex from a command line. Write up your LaTeX file with a text editor. Then open a DOS prompt, change into the directory where your file resides, and run "pdflatex <myfile.tex>" to turn your latex directly into a pdf file. If you need help writing a LaTeX file, let us know.
- Warren
PF uses a combination of three programs: latex, dvi2ps, and pstoimg. Latex converts input to dvi, dvi2ps converts that to postscript, and finally pstoimg renders the postscript to an image.
- Warren
When you say text editor? Do you mean Word? or Notepad?? Those are the only two I know of ! MikTex does not give me some default text editor nor does it seem to provide any Latex text editor so where should I get an editor if I don't already have one?
Then open a DOS prompt, change into the directory where your file resides, and run "pdflatex <myfile.tex>" ...I have XP so I guess it would have to be the Command Prompt right? The directory in which my file is would be C:/ right?
When you say run "pdflatex <myfile.tex>" do you mean Start ---> Run and enter the thing?
James
Notepad is a fine text editor. I would not use Word, because it may be a pain to make Word save in plain text format. Personally, I use an editor called TextPad: www.textpad.com
To open a command prompt, go to Start, hit Run, type "command" and hit enter.
I don't know where you save your files. Making a directory under C: is probably a fine idea.
In the command prompt, type "pdflatex myfile.tex", where myfile.tex is just a sample file name. Yours will probably be different.
- Warren
Thanks...trying it right now.
One thing...when I save it in notepad, it saves it as a .txt file.
I don't think latex really cares about the endings of your filenames, but you might want to rename it to end in .tex just in case.
- Warren
ok It said I can't find the file myfile.tex...I labelled it markus.tex
How do I get it to the C: prompt? I type C:\ but it says that it is not recpgnized as an internal or external command
Put your file, markus.tex, in a directory like c:\tex.
In the command prompt, type "cd c:\tex" then type "pdflatex markus.tex"
- Warren
Surely Windows must have a GUI implementation that hides this from the user? Why not use one of those if your not comfortable with working on a command-line?
Dr-NiKoN,
I'm not so sure a GUI interface exists for Windows; nor am I sure that such a GUI would really be easier than just typing 'pdflatex'. If you know of one, please give us more information. If not, please don't assume there is one.
I suppose you could put the commands in a batch file, which you could then double-click.
- Warren
It still says that it cannot find the file...I give up...it' s just not worth it...I am spending hours each day and getting nothing out of it...not worth it...if it is available on CD maybe I should explore that option.
It's going to be the same software on CD. Learning to use your computer (basic file manipulation operations and so on) will benefit you greatly down the line, particularly if you are a student.
- Warren
Is there some way to open it from latex itself? I have selected all the latex packages in the miktex package manager and installed them...Could I get it to convert to pdf by opening one of them?
This is an online tutorial and I am trying to follow it
At the shell prompt type latex myfile You will see a number of lines of text scroll by in the screen and then you get the prompt back. To view the output in screen, you must have the X Window running . So, start X if you have not done so, and in a terminal window, type xdvi myfile
What is the Xwindow, shell prompt and how do I access them?
As far as I know, the only way to invoke latex is via the command line. You might want to consider one of the packages Dr Transport suggested, but I do not know how to use them.
- Warren
The X Window System is used on UNIX computers. You don't need to worry about it. It provides a graphical display somewhat like that provided by Windows.
The "shell prompt" is the same as the command prompt I have been talking about, just in UNIX terminology.
- Warren
I am trying to uninstall MikTex and re-install it but when I click Add/Remove programs, I do not see Miktex for some reason...how should I uninstall...should I remove each package one by one?
If you have MS Word, and you are simply trying to put math into your typed lab reports etc., then use the built in equation editor.
In Word, go to Insert-Object-Equation 3.0
That will open a small box in your document where the equation will go, and it gives you toolbar to select your symbols etc.
You will be up and running in less than a minute. Then you can spend more time writing your report and concentrating on content than fiddling with software.
Let me know if you like it, and if this is what you need.
9K
14K
