Solve Kinematics (3 in 1) Problems with Omid
  • Thread starter Thread starter Omid
    Kinematics
This discussion focuses on solving three kinematics problems related to vehicle stopping distances and traffic light timing. The first problem involves calculating the smallest stopping distance (S_s) using the formula S_s = (v_i)(0.6 s) - [((v_i)^2) / 2a], yielding a numeric answer of 12.67 meters for a speed of 35 km/h. The second problem requires deriving a time (t_y) for the yellow light that is independent of S_s, while the third problem calculates the total time the yellow light should remain lit, considering a 25 m intersection width. The key challenge lies in ensuring the derived equations meet the problem's constraints.
  • Understanding of kinematics principles, particularly stopping distance calculations
  • Familiarity with vehicle dynamics, including acceleration and response time
  • Ability to manipulate algebraic equations for solving physics problems
  • Knowledge of traffic light timing regulations and their implications
  • Research the derivation of kinematic equations for constant acceleration
  • Learn how to calculate stopping distances for various vehicle speeds and conditions
  • Explore traffic engineering principles related to yellow light timing and safety
  • Investigate the effects of driver reaction times on traffic signal design
Students studying physics, traffic engineers, and anyone involved in road safety and vehicle dynamics will benefit from this discussion.
Omid
Here there are 3 related problems which I need help with them :
37. Imagine that you are driving toward an intersection at a speed v_i just as the light changes from green to yellow. Assuming a response time of 0.6 s and an acceleration of -6.9 m/s^2, write an expression for the smallest distance (S_s) from the corner in which you could stop in time. How much is that if you are traveling 35 km/h?
I suggest this expression :
S_s= (v_i) (0.6 s) - [((v_i)^2) / 2a ]
And 12.67 as the numeric answer for the second part.
38. Considering the previous problem, it should be clear that the yellow light might reasonably be set for a time t_y, which is long enough for a car to traverse the distance equal to both S_s and the width of the intersection S_I.
Assuming a constant speed v_i equal to the legal limit, write an equation for t_y, which is independent of S_s.
I just don't get this one.
40. With problems 37 and 38 in mind, how long should the yellow light stay lit if we assume a driver response time of 0.6 s, an acceleration of -6.9 m/s^2, a speed of 35 km/h, and an intersection 25 m wide ? Which of the several contributing aspects requires the greatest time ?
I don't understand this one too.
Thanks
Omid
You wrote "-" in the formula but clearly intended "+" (and used + to get 12.67)
38. You already have a formula for S_s. S_i is just some (given) fixed number. The distance you need to "traverse" as speed v_i is just the sum of those:
(v_i) (0.6 s) + [((v_i)^2) / 2a ] + S_i. What time is needed to go that distance at constant speed v_i ?
40. Now that you have finished 38 (what happened to 39?) just put the numbers you are given: v_i= 35, S_i= 25, etc. into the formula.
Yet there are 2 questions for me.
1. The formula for t_y ( problem 38 ) is not INDEPENDENT of S_s as the problem asks to be (our formula is : (v_i) (0.6 s) + [((v_i)^2) / 2a ] + S_i which is equivalently (v_i) (0.6 s) + [ S_s ] + S_i ).
2. Which of the several contributing aspects requires the greatest time ?
I think it's v_i, isn't it ?
  • · Replies 22 ·
  • · Replies 29 ·
