What is the pH at different points in a titration of CH3NH2 with HNO3?
  • Thread starter Thread starter _Bd_
    Buffers Chem
The discussion focuses on calculating the pH at various stages of a titration involving 30.0 mL of 0.3 M CH3NH2 (methylamine) with 0.15 M HNO3 (nitric acid). Key points include the use of Kb (4.4 x 10^-4) to find pOH and the construction of an ICE table to analyze the reaction: HNO3 + CH3NH2 → CH3NH3+ + NO3-. The participant correctly identifies the need to calculate pH at the initial state, after adding 10.0 mL of acid, at the half-equivalence point, at the equivalence point, and after adding 70 mL of acid.
  • Understanding of acid-base titrations
  • Knowledge of ICE tables for equilibrium calculations
  • Familiarity with the concepts of pH, pOH, and Kb
  • Ability to perform molarity calculations
  • Learn how to calculate pH at the half-equivalence point in titrations
  • Study the relationship between Kb and Ka using the formula Ka = Kw/Kb
  • Explore the titration curve for weak bases with strong acids
  • Practice constructing ICE tables for various acid-base reactions
Chemistry students, educators, and anyone involved in analytical chemistry or titration experiments will benefit from this discussion.
_Bd_
You are titrating 30.0 mL of .3 M CH3NH2 with .15 M HNO3 Kb = 4.4 x 10^-4. Calculate
pH:
-initially
-after 10.0 mL of acid has been added
at the half equivalence point
when 70 mL of acid has been added.
not sure. . .
I was thinking that since Kb is given I can get the pOH using the fact that
[OH] = [tex]\sqrt{K_b x Molarity}[/tex] <- im not sure if this is correct tho.
then do an ICE table for the reaction. . . I am not sure about the reaction tho. . .
HNO3 + CH3NH2 >> CH3NH3+ + NO3- . . .is that it?
the first ICE table should be a limiting reagent problem?
knowing the moles of both after 10 mL yields:
.0015 | .009 ...| 0....|0 <<<<<<<<<<Initial
-.0015 |-.0015 ...| +.0015 ...| +.0015 <<<<<<<<Consumed
0 ...|.0075 .....| .0015 ...| .0015 <<<<<<< Final
so I can get K at this point right? (K = products/reactants) but that's Ka or Kb?
  • · Replies 16 ·
35K
11K
