How Do You Determine Scalars a and b from Vectors A, B, and C?
  • Thread starter Thread starter Dorita
    Scalars Vectors
The discussion revolves around determining the scalars a and b from the equation involving vectors A, B, and C, specifically the equation aA + bB + C = 0, where A, B, and C are defined in component form.
  • Participants explore the interpretation of the equation, with some questioning the setup and others suggesting to break down the vector components to form equations. There is also a discussion about the meaning of scalars in this context.
The conversation is ongoing, with participants clarifying misunderstandings about the equation and the nature of scalars. Some have provided insights into vector addition and component comparison, while others are still trying to understand the problem's requirements.
There is a noted typo in the original post regarding the equation, which has led to some confusion. Additionally, one participant has misapplied a formula that is not relevant to the vector problem at hand.
Dorita
I saw this question posted yesterday, and now got a similar question to work out.
A = (6i-8j) cm
B = (-8i+3j) cm
C = (26i+19j) cm
aA+bB+C=0
Determine the two scalars a and b.
Ideas anyone??
Thanks
Dora
C=0 ?? But you just said C=26i+19j . Is this a typo? or did you mean aA+bB-C=0
in which case aA+bB=C
seems pretty straightforward to me. Split it up into the vector components, and youll have 2 equations with 2 unknowns, easily solveable.
Sorry. That was a tipo. I made a mistake.
aA+bB+C=0 not aA+bB=C=0 not
Well, what have you done so far? How have you approached it?
I used the equation a^2 + b^2 = c^2 and the coodinates (6,-8) and (-8,3) to determine that the magnitude of A is 0.5cm and that the magnitude of B is 0.7cm. But I don't know if that is what is meant by "determine the two scalars a and b". I'm asuming scalars in this question is the scalar quantity or "magnitude".
The "equation a^2+ b^2= c^2" doesn't even make sense here. You are given vectors A, B, C, not numbers a, b, c (and you certainly don't have any number c).
Do you know how to add vectors and multiply vectors by a number? That should have been ther first thing you learned!
If A= 6i+8j, then aA= (6a)i+ (8a)j.
If B= -8i+ 3j, then bB= (-8b)i+ (3b)j
aA+ bB = (6a- 8b)i+ (8a+ 3b)j and that must be equal to C= 26i+ 19j.
Okay, have you learned that two vectors are equal only if the respective components are equal?
To have aA+ bB= C, you must have (6a- 8b)i+ (8a+ 3b)j= 26i+ 19j and so
6a- 8b= 26 and -8a+ 3b= 19.
Can you solve those two equations for a and b?
16K
  • · Replies 25 ·
  • · Replies 17 ·
