How to Determine Maximum RPM of a Spinning Disc?
To determine the maximum RPM of a spinning disc, one must consider the concept of disk burst, which is a preliminary design tool used for turbines and other rotating components. The maximum RPM is influenced by the centrifugal force acting on the disc and its yield strength. Specifically, for safety and design purposes, it is crucial to evaluate the rupture strength or ultimate strength of the material to prevent catastrophic failure.
  • Understanding of disk burst concepts
  • Knowledge of yield strength and rupture strength
  • Familiarity with centrifugal force calculations
  • Basic principles of turbine design
  • Research disk burst calculations for rotating components
  • Study material properties related to yield and rupture strength
  • Explore centrifugal force equations and their applications
  • Investigate safety factors in turbine design
Engineers, mechanical designers, and anyone involved in the design and analysis of rotating machinery, particularly those working with turbines and high-speed discs.
mechdesignron
Hello,
I would like to know how to determine the max RPM of a disc. I would think it would be the centrifugal force against the Yeild Strength. Any help would be appreciated.
Thanks,
Ron
What you're looking for is something called disk burst. It's a preliminary design tool for turbines and other rotating components.
As far as what the limit is, well then it depends on your design criteria. If you're looking for the point where the disk explodes, then you'll want to look at rupture strength or ultimate.
  • · Replies 33 ·
  • · Replies 23 ·
12K
  • · Replies 20 ·
