How Do You Calculate Work Done by a Force Field Along Different Paths?
The discussion focuses on calculating work done by a force field defined as F = (1/r^2)r, where r is a unit vector. The user successfully computed the work done along a direct radial path from r = sqrt(2) to r = 2*sqrt(2), yielding a result of sqrt(2)/2. However, they faced challenges in calculating work along a segmented path from (1,1) to (2,1) and then to (2,2), particularly in setting up the x and y components correctly for the line integral. Guidance was provided on using parameter equations for integration and the importance of the vector components in the calculations.
  • Understanding of vector calculus and line integrals
  • Familiarity with force fields and their mathematical representation
  • Knowledge of parameterization of curves in two dimensions
  • Proficiency in integrating functions involving trigonometric identities
  • Study the principles of vector fields and line integrals in depth
  • Learn how to parameterize curves for integration in multiple dimensions
  • Explore the application of arctangent functions in integral calculus
  • Review examples of work done by force fields in physics
Students and professionals in physics, engineering, and mathematics who are working with vector fields and need to calculate work done along various paths.
ossito_the-diracian
My problem has force decreasing with F=(1/r^2)r, where F is a vecotr and r is unit vector. i need to find a).work done in moving from a point at r=sqrt(2) to a point at r=2*sqrt(2) by a direct radial path and (b) by a path from (1,1)-->(2,1)-->(2,2). Compare my answers.
a)I did direct radial path using Work=Integral[1/r^2] from sqrt(2) to 2*sqrt(2). I got sqrt(2)/2.
b) This where problem is: from (1,1)-->(2,1) x:1-->2, y=1, dl=dx x, so i get F (dot) dl = (x^2+y^2)^2, however, I am not sure I am setting up the x and y components correctly. from (2,1)-->(2,2) y:1-->2, x=2 dl=dy y and again same issues of x and y components.
i did read that r vector=sin(theta)cos(phi)x+sin(theta)sin(phi)y, but was not sure how to incorparate this into line integral part of problem.
any help would be appreciated, thanks
First of all this is a vector-integral. This means that you are going to have to calculate this integral for each component. In your case we have two components x and y so r²=x² + y².
Now (1/r²)rdr = (1/r²)dx + (1/r²)dy. Because the unitvector multiplied by the vector dr gives you dx and dy (via the dot-product)
Now when you move from (1,1) to (2,1) you will need a parameter-equation for the integration. y = 1 and x=l with l the parameter and l : 1-->2. So in the integral replace x by l and dx=dl and y = 1 and dy =0
The x-component of the integration is integral(dl/(l²+1²)) and l starts in 1 and stops in 2. this integral is easy because you know that generally
integral(1/(1 + x²)dx) yields arctan(x).
Since along this path dy = 0 the second term of the integral vanishes...
So the only thing you need to do now is calculate the integral correctly. But the solution of this integral will be an arcus-tangens...
The other path is calculated in the exact same way.
regards
marlon
thanks a bunch, I was sort of close, but never looked at the vector part of it. My first integral where dy=0 I was using (x^2+1)dx from 1-->2. I should be able to complete it now, again thank you.
