Thread Closed
Energy and Current
Share Thread
Oct1-10, 10:53 PM   #1
Energy and Current
What is the total energy dissipated as heat in a resistor of resistance R = 80.0 Ω when a current of I = 0.09 A passes through it for 1 minute?
2. Relevant equations
3. The attempt at a solution
From the given values I can work out the potential difference, but I'm stuck here because I don't know what formula to use with energy in it. But I know that electric power can be found from P=IV=I2R, but I don't know how this helps to find energy. Of course I know that [tex]P=\frac{dU}{dt}[/tex], but I don't see how to solve for the energy...
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Oct1-10, 11:09 PM   #2
It seems you have the answer hiding right in front of you...
If you know that the power drop across a resistor is (I^2)(R) then you can calculate that given the values.
Next if you assume that it drops all that power through heat 'U' over that 1min and you know that P=U/t then...
Thread Closed
Similar discussions for: Energy and Current
Thread Forum Replies
Electrical current and Resistance and Energy Introductory Physics Homework 1
Energy in an ocean current vs energy in an air current Engineering, Comp Sci, & Technology Homework 4
Current, Power, and Energy problem Introductory Physics Homework 10
Voltage, current, energy and charge General Physics 11
