How Do You Calculate the Effective Stiffness of an Iron Bar?
  • Thread starter Thread starter ohheytai
    Spring Stiffness
The effective stiffness of an iron bar can be calculated using the formula ks = F/x, where F is the force applied and x is the extension of the bar. In this discussion, a 234 kg mass causes a 1.22 cm elongation in a 2.4 m long iron bar with a square cross-section of 0.15 cm. The calculated effective stiffness is approximately 0.0046 N/m. Additionally, the speed of the wave traveling through the bar can be determined after striking it, which is essential for understanding wave propagation in solid materials.
  • Understanding of Young's Modulus and Hooke's Law
  • Basic knowledge of mechanics and material properties
  • Familiarity with units of force and length in the metric system
  • Concept of wave propagation in solids
  • Research the calculation of Young's Modulus for different materials
  • Learn about wave speed in solids and the factors affecting it
  • Explore advanced applications of Hooke's Law in engineering
  • Investigate the relationship between density and stiffness in materials
Mechanical engineers, materials scientists, and physics students interested in the mechanical properties of materials and wave dynamics in solids.
ohheytai
What is the Spring Stiffness?
1. One mole of iron (6.02x10^23 atoms) has a mass of 56 grams, and its density is 7.87 grams per cubic centimeter. You have a long thin bar of iron, 2.4 m long, with a square cross section, 0.15 cm on a side.
You hang the rod vertically and attach a 234 kg mass to the bottom, and you observe that the bar becomes 1.22 cm longer. Calculate the effective stiffness of the interatomic bond, modeled as a "spring":
Next you remove the 234 kg mass, place the rod horizontally, and strike one end with a hammer. How much time t will elapse before a microphone at the other end of the bar will detect a disturbance?
Youngs Modulus? or Hookes law?
ks = F/x
and i tried using youngs modulus doing it the long way and i got .0046 still wrong
You can solve it by ks=F/x, but what values are you using for F and x? And regarding part 2, at what speed does the vibrating wave travel?
21K
13K
13K
  • · Replies 19 ·
12K
