Maximums and Minimums: Why is the Lower Limit Not 1 in This Set?
  • Context: Graduate
  • Thread starter Thread starter hitmeoff
The discussion revolves around the concepts of minimum and maximum values of sets in the context of real analysis, specifically examining examples from a textbook. Participants explore the definitions and implications of these concepts, particularly in relation to sets defined by specific mathematical expressions.
  • One participant notes that the set {r in Q: 0 =< r =< Sqrt(2)} has a minimum of 0 but no maximum, as Sqrt(2) is not included in the set of rationals.
  • Another participant expresses confusion about why the set {n^(-1^n) : n in N} has no minimum, questioning why 1 is not considered the lower limit since it is the smallest natural number.
  • A later reply clarifies that the numbers generated by the second set include fractions, which are not natural numbers, thus affecting the minimum value.
  • One participant suggests that the first set is explicitly bounded while the second is not, leading to different interpretations of minimum values.
  • Another participant reflects on their understanding of set notation, attempting to clarify the nature of the sets and their bounds.
  • A third example involving the set {n in Z: 1 =< ln n =< 10} is introduced, with participants questioning how to interpret the minimum and maximum values based on the function ln n and the restriction to integers.
Participants express differing interpretations of the minimum and maximum values of the sets discussed. There is no consensus on the correct understanding of the examples, and confusion remains regarding the implications of set notation and the definitions of minimum and maximum in these contexts.
Participants highlight limitations in their understanding of set notation and the implications of the definitions of minimum and maximum values. The discussion reveals dependencies on how sets are defined and the nature of the elements within those sets.
hitmeoff
Hello all,
I am currently taking Intro to Real Analysis and we are using Elementary Analysis by Ross. We are on Section 4, dealing with the completeness axiom, but we have only got as far as defining the minimum and maximum of a set (we have not discussed the completeness axiom, archimedean property, upper/lower bounds, supremums/infimums).
We went over Ross' examples in class and I have revied the examples myself and I am confused why the following is so:
1) The set {r in Q: 0 =< r =< Sqrt(2)} has a minimum, namely 0, but no maximum. This is because Sqrt(2) does not belong to the set, but there are rationals in the set arbitrarily close to Sqrt(2).
Ok, I get that. But the next example says:
2) Consider the set {n^(-1^n) : n in N}. This is shorthand for the set {1, 2, 1/3, 4, 1/5, 6, 1/7...} The set has no maximum and no minimum.
Ok, I understand why there is no maximum to the set, there are infinitely many more naturals that this set generates (ie. 8, 10, 12, 14.. -> infinity). What I do not understand is why is the lower limit not 1? 1 is the smallest possible natural number in this set. I know the set continues towards zero getting closer and closer to zero without ever reaching there, but those fractions are not naturals.
If in the first exampl2 Sqrt(2) is not the max because it is not a rational and you can get infinitely many rationals on your way to Sqrt(2) (ie. the max is restricted to rationals) why is the minimum of the second example not 1 (if we are restricting the min to naturals)?
Is it because the set in the first example is explicitly bounded by 1 and Sqrt(2) but the set in the second example is not explicitly limited?
Anyone?
hitmeoff said:
Hello all,
It said "n in N". That does NOT mean that the numbers in the set are in N! The numbers in the set are, as it said, 1, 2, 1/3, etc. It would not say those numbers are in the set if it were intended to restrict the set to the integers.
Because the first example specifically said that the numbers in the set were natural numbers. The second example said the number, n, used to generate the numbers in the set was restricted to the natural numbers but did NOT say that the numbers in the set had to be natural numbers and the numbers shown as belonging to the set are clearly NOT natural numbers.
No, the first set is clearly has 0 as a lower bound, whether "explicite" or not.
Ok, I think I get it. Maybe I am getting confused on reading set notation.
So if we say the set S = {r in Q: 0 =< r =< Sqrt(2)} is like saying the set of rationals ranging from [0, Sqrt(2)] In which case 0 is a rational and the smallest value of the set so its the minumum and there is no maximum because there are infinitely many rationals on the way to Sqrt(2).
and
set T = {n^(-1^n) : n in N} is like saying the set of values generated by the function n^(-1^n) with the naturals as input. There is no min or max because there is no minimum or maximum value to the function.
Am I right on this? If I am, then let me point out a third example given by the professor:
{n in Z: 1 =< ln n =< 10} So do I read this "the set of values given by the function ln n, in the range [1, 10], with integers as the input"? So why is the min of this set 3? I know e^1 is 2.7... so the nearest integer is 3, but why are we restricting the min to just integers? obviously n can only be those numbers in the interval [e^1, e^10], I just don't get how 3 is even a member of this set? Is this set not: {ln 3, ln 4, ln 5...ln 22026} (e^10 = 22026.46...}
Or should I read {n in Z: 1 =< ln n =< 10} like "the set of integers n, subject to the function ln n in the interval [1,10]" in which case the integer 3 is the smallest integer that, when subject to ln n, gives a value that is in the interval [1,10]? Would the max of this set then be 22026?
In other words, is this set : {3, 4, 5,...22026}?
  • · Replies 16 ·
  • · Replies 85 ·
9K
  • · Replies 53 ·
12K
  • · Replies 35 ·
