What are the Best Tires for a Fuel Efficient Car?
  • Thread starter Thread starter blumist
    Tires
The discussion revolves around selecting the best tires for a fuel-efficient car being designed for the Shell Eco Marathon. Participants explore various tire options, engine positioning, and design considerations to maximize fuel efficiency while addressing specific performance requirements.
  • One participant inquires about lightweight tires that minimize rolling friction for a small, fuel-efficient car with a carbon-fiber chassis.
  • Another participant suggests that engine positioning may not directly affect efficiency, but aerodynamics and cooling considerations are important.
  • There is a discussion on the suitability of bicycle tires for low-speed vehicles, with some arguing they could provide minimal rolling resistance.
  • Concerns are raised about cornering dynamics, noting that the cornering behavior of bicycles differs from that of cars, which may affect tire choice.
  • A participant mentions the goal of achieving maximum fuel efficiency for a car designed for a specific race, detailing the car's weight and dimensions.
  • Suggestions include using carbon fiber racing bike wheels and lightweight racing tires, emphasizing the need to consider cornering loads and tire pressures.
  • Another option proposed is motorcycle wheels for slightly higher speeds, while reiterating that bicycle tires may suffice for lower speeds.
  • One participant requests specific tire recommendations and information on tire rolling drag coefficients.
  • Another participant suggests searching for "bike rolling resistance" for further information on tire performance.
Participants express a range of opinions on tire selection, with some advocating for bicycle tires and others suggesting alternatives like motorcycle wheels. The discussion remains unresolved regarding the optimal tire choice and the impact of engine positioning on efficiency.
Participants have not defined specific performance requirements or constraints for tire selection, leading to varying recommendations based on assumptions about speed and handling.
Whats better? Front wheel or Rear wheel drive?
  • Total voters
  • Poll closed .
blumist
Hi,
I am currently working on a project of building a fuel efficient car. My car has a carbon-fiber chassis, a glass-fiber mainframe and weighs about 110 k.g.s(with driver). I need to find some light weight tires that would go just about right with the rest of the design and also be able to control the overall rolling friction.
Also, i wanted to know if placing the engine in the rear of the car improves the efficiency or not.
Thankyou
Engine positioning won't directly matter. However, other related considerations will. Aerodynamics will play an important role, so if there's a 'bulge' where the engine is located, or vents required for cooling/aspiration then you'll need to think about that.
Tyres will depend on loads of things; what kind of car is this? A tiny, low speed, lightweight tarmac vehicle might get away with using bicycle tyres, anything faster will need something more specialised.
its a small car actually... a single driver would hardly fit in. Its about 2 meters in length and 110 cm high. What i need to do is increase its efficiency to as high as possible. Would bicycle tires do good? Anything else that i need to be taking into consideration? Thanks for the help.
Well as I said, if it's not going to be doing high speeds, bicycle tyres would do a very good job. Think about it; road bike users are after pretty much exactly the same thing you are (minimum rolling resistance). One thing to consider if you go down that route is cornering; the way bikes and cars corner (and the associated loads on wheels and tyres) are fundamentally different. Give it some thought.
However, if you're going to be doing higher speeds, or have some other requirements (perhaps traction for acceleration/cornering/braking), grip, wet weather or non-tarmac performance, then you might need something else. You haven't really defined your requirements.
Ok here goes,
I am planning to build a car worthy enough of participating in the Shell Eco marathon 2011. Now i have the design and power needs sorted out at the moment but there is still a lot i have to do here. Here is the basic goal that me and my team are working on.
"To build a car that can provide maximum attainable fuel efficiency"
Now we have chosen a chassis design that combined with the engine and the body weighs less than 60 k.g. The car is only 110 cms high and about 50 cm in width so air traction is almost controlled thanks to an aerodynamic design.
We are facing problems in choosing the right tires that would provide minimum friction. Our car won't do speeds above 30 kph and there are no tight corners or off-road patches on the track so its basically a 25 kph constant smooth drive on a race track. Our chassis design includes 3 tires to be places. 2 on the back, and one on the front. Now the braking system has to be strong enough to hold the car static while placed on a 30* slope. These are pretty much all of my requirements.
I'd go with carbon fibre racing bike wheels and lightweight racing tyres, and be sure to get the cornering loads right (bikes don't corner like cars). With the extra weight you will need to consider tyre pressures.
Another likely option if you wanted slightly higher speeds would be the motorcycle wheels with spokes. They are much lighter than car wheels and perform nicely for light weight vehicles. This is only if you want to attain higher speeds. For low speeds, the cycle tires should do fine.
thanks for the info. Do you have any tires in mind that would do good?
I need to get the exact tire rolling drag co-efficient. Please point me to a link on the web that would serve my purpose. Thanks again!
No, it's your project, I'll leave it with you here...
Search "bike rolling resistance".
You can test how much side load capacity a particular set of tires/wheels has by pulling sideways on the car. I think you'll find that regular bike wheels will withstand the cornering loads that you can expect but if your testing indicates the need, use wider hubs.
