Crystall structures of Cu, Al, and Fe at different temperatures.
  • Thread starter Thread starter SrEstroncio
    Structures
The discussion revolves around the crystal structures of aluminum, copper, and iron as a function of temperature. Participants explore the concept of allotropy and polymorphism, and how these phenomena affect the crystal structures of these metals at different temperatures.
  • One participant notes that aluminum and copper have a face-centered cubic (FCC) structure at room temperature, while iron has a body-centered cubic (BCC) structure.
  • Another participant introduces the concept of allotropy, explaining that it refers to a single element having multiple crystal structures, specifically mentioning iron's allotropes.
  • A participant suggests that the reasons for an element's crystal structure at a given temperature are complex and may involve theoretical modeling related to electron energy distribution.
  • Polymorphism is mentioned as a relevant concept, with a participant suggesting that it includes displacive and reconstructive changes in crystal structure.
  • Specific temperature points are discussed, indicating that iron transitions from γ-Fe (FCC) to α-Fe (BCC) at 912℃, with associated changes in coordination number and atomic radii.
Participants present multiple viewpoints regarding the crystal structures and the underlying reasons for changes at different temperatures. There is no consensus on the simplicity or complexity of the explanations for these phenomena.
Some limitations include the lack of detailed explanations for the underlying mechanisms of allotropy and polymorphism, as well as the dependence on specific conditions for material formation.
SrEstroncio
I was wondering if someone could tell me (in pedestrian terms) what are the crystal structures of aluminum, copper and iron as a function of the temperature.
I just read the chapter on crystalline arrays of Callister's Materials Ecience & Eng. but the book just says that Cu and Al have a FCC structure at room temperature, while Fe has a BCC structure, but it doesn't go much farther than that, and as I have basically no previous knowledge of the subject, I can't easily read more advanced texts.
Thanks in advance.
Note. Since this isn't a standard problem-solution type of question I posted it here instead of the homework help sections; please tell me if I should change this.
The phenomenon of a single element having multiple crystal structures is called allotropy. Here's the wikipedia article on the allotropes of iron for example: http://en.wikipedia.org/wiki/Allotropes_of_iron
If you only want to know what the crystal structures are at various temperature, that's probably information that you can search for. As for the exact reason why an element takes the crystal structure that it does at a given temperature, I'm afraid that that's a complicated condensed matter physics problem, which probably doesn't have any intuitive explanation in most cases. I expect it has to do with the energy distribution of the electrons in the solid at a given temperature, among other things. It probably requires some complicated theoretical modelling.
It can also depend on the exact conditions in which the material forms, but that's kind of a less fundamental issue.
Maybe there is a simple physical picture in some of these cases, but I wouldn't hold your breath! Let me know if you find out. :)
well, there is a concept called polymorphism.including displacive and reconstructive.You can get well understanding if you have a look of the book "Fundamentals of Materials Science"
normally, Fe will translate from γ-Fe to α-Fe at 912℃. and the former is FCC, while the latter is BCC. The polymorphism will cause the change of coordination number, which will further cause the change of the radii of the atom. Just take Fe for example, the coordination number changes from 12, FCC, to 8, BCC, and the change of the unit volume is about -0.00641
29K
11K
