Find Coefficient of Friction (μ) on Cylinder with Rope and Cat/Mice Forces
  • Thread starter Thread starter Super_Leunam
    Cylinder Rope
The discussion focuses on calculating the coefficient of friction (μ) for a scenario involving a cat pulling on a rope wrapped around a fixed cylinder, with a total angle of contact of π/3 radians. The relationship between the forces exerted by the cat (F) and the mice (f) is determined using the belt friction equation, which accounts for static friction and the varying tension along the rope. The solution involves deriving an exponential function that relates μ to the forces and the angle of contact.
  • Belt friction equation
  • Static equilibrium conditions
  • Basic calculus for integration
  • Understanding of forces and tension in ropes
  • Study the derivation of the belt friction equation in detail
  • Learn about static equilibrium and its applications in physics
  • Explore exponential functions and their relevance in mechanics
  • Investigate real-world applications of friction in pulley systems
Physics students, mechanical engineers, and anyone interested in understanding friction dynamics in systems involving ropes and pulleys.
Super_Leunam
WOULD SOME1 HELP ME WITH THIS ANNOYING PROBLEM I CANT SOLVE :
a cat is wrapped around a fixed cylinder .there's friction between the rope and da cylinder with a coefficient of friction (mu) , the angle covered by the rope on the cylinder is (pi)/3 .assume a really thin rope. A cat is pulling on one end of the rope with a force F while 10 mice can just barely prevent from sliding by applying a total force of f . Find (mu) in function of F, f and the angle
i know the answer is has to do with an exponential
thanks
Manuel
Due to static friction with the cylinder, the tension on the cat end of the rope will be greater than on the mouse end. The relationship between the two tensions, the angle of contact, and mu is given by the so-called "belt friction equation". You can derive it by consider a small element of rope and applying static equilibrium conditions. Then integrate this over the full angle of contact.
Yes, it is an exponential function. :smile:
Super_Leunam said:
a cat is wrapped around a fixed cylinder.
Poor thing!
I like cats :frown:
  • · Replies 32 ·
  • · Replies 47 ·
10K
9K
