| Thread Closed |
Thermal energy conversion |
Share Thread |
| Oct6-10, 04:03 AM | #1 |
Hello! I was wondering if someone could take a look at this idea and tell me if there is something wrong with it:
In attempting to shut down every part of a hypothetical spacecraft except some sort of highly insulated crew pod, the total amount of heat produced over a period of time is equal to the total calories consumed minus any useful mechanical work performed. If a person consumes an average of 2400 kilocalories per day, the average heat produced is 100 kilocalories per hour or 116 watts. Ignoring all other assumptions, if you were to convert that heat buildup to electrical storage, you get 20 crew x 1 day, 55.68 kilowatts. A kilogram of Li-ion stores 128 Wh[1], so you need 435 kilograms to store the heat energy of the crew for the day. Multiply that by 120 days and you get a little over sixty tons of Li-ion batteries required for a four month journey, easy to fit in on a ten thousand ton ship. With lithium thionyl chloride, used in extremely hazardous or critical applications such as space flight and deep sea diving, you get a little over 10 tons needed. Now you probably won't get all of the thermal energy, but using new technological advances [2] and say dunking the lot in water to slowly absorb the rest for four months, could you conceivably keep a vessel of this sort at or as near to ambient as makes no odds? [1]http://www.allaboutbatteries.com/Battery-Energy.html [2]http://www.sciencedaily.com/releases...0930154610.htm |
| Oct6-10, 05:48 AM | #2 |
Uhm seems like you are ignoring the second principle of thermodynamics. To convert thermal energy to work you need to reservoirs at different temperatures. A lower ratio between the lesser temperature and the upper temperaturemakes the efficiency of you thermal engine higher. Assuming you have an internal temperature equal to 300 Kelvin, what do you plan the lower temperature resorvoir to be?
| Oct6-10, 05:56 AM | #3 |
| Oct6-10, 11:17 AM | #4 |
So it should be technically doable?
| Oct7-10, 10:31 AM | #5 |
![]() So the maximum possible efficiency would by 99% in this case, so you'd only need to absorb around 60 kilowatts of heat for the entire journey? Note that you could vent it afterwards, its just being stored long enough to get there. |
| Thread Closed |
Similar discussions for: Thermal energy conversion
| Thermal to electric conversion with diodes | Atomic, Solid State, Comp. Physics | 1 | ||
| The conversion of electrical energy to heat energy. | Introductory Physics Homework | 7 | ||
| Alkali Metal Thermal Electric Conversion (AMTEC) | Nuclear Engineering | 0 | ||
| Earth mass conversion to thermal energy | General Physics | 14 | ||
| Thermal Conductivity Conversion | Materials & Chemical Engineering | 2 | ||
