| Thread Closed |
asymptote |
Share Thread | Thread Tools |
| Sep18-04, 12:14 PM | #1 |
asymptote
f(x)=(9x^2-36)/(x^2-9)
I forgot how to get the hotizontal asymptote. Is it f(x)=0? When I do that, there is no way to solve it Also, how do I find the intervals for when f is increasing? I'm not asking for the answer, but the equation, I totally forgot thanks |
| Sep18-04, 12:53 PM | #2 |
Horizontal (right-hand side) asymptote: [tex]\lim_{x\to\infty}f(x)[/tex]
Horizontal (left-hand side) asymptote: [tex]\lim_{x\to-\infty}f(x)[/tex] What does the derivative of a function tell you about the function's behaviour? |
| Sep18-04, 12:57 PM | #3 |
I'm even more confused. I know that getting the vertical asymptote is setting the denominaor equal to zero and solving for it but what is it for the horizontal?
| Sep18-04, 01:02 PM | #4 |
Recognitions:
asymptote
are you familiar with limits?
| Sep18-04, 01:02 PM | #5 |
The line g(x)=L (parallell to the x-axis!) is called the horizontal asymptote to f(x) |
| Sep18-04, 01:19 PM | #6 |
So how would I find the equation for each horizontal asymptote of: f(x)=(9x^2-36)/(x^2-9)
| Sep18-04, 01:27 PM | #7 |
Think this way:
Let x be a huge positive number. Then, surely, 9x^2 must be a lot larger than 36. Similarly, x^2 must be a lot larger than 9. Hence, you don't make a big mistake by setting: [tex]9x^{2}-36\approx9x^{2}[/tex] (the relative error is tiny) Similarly: [tex]x^{2}-9\approx{x^{2}}[/tex] Hence: [tex]f(x)=\frac{9x^{2}-36}{x^{2}-9}\approx\frac{9x^{2}}{x^{2}}=9[/tex] (for huge positive x's) Hence, the horizontal right-hand asymptote is L(x)=9 |
| Sep18-04, 01:38 PM | #8 |
I understand your process of thinking however, is there a specific formula that can calculate that number?
I know that to obtain the vertical asymptote, it's by setting the denominator to zero. e.g. f(x)=(9x^2-36)/(x^2-9) x^2-9=0 x=+3,-3 so the equations for the vertical asymptote is x=3 and x=-3 how do I do this with the horizontal asymptote? |
| Sep18-04, 02:01 PM | #9 |
No, there is in general no foolproof method in determining limit values (in your case, to get the horizontal asymptotes)
There exist a rigourous method which in principle tells you whether a chosen number is a limit or not (i.e, if you've made a right (or wrong!) guess) The reasoning I gave you, however, is sufficient to determine the horizontal assymptotes you'll meet. So here's a method, if you like: 1. Think of x as a huge number. Practical meaning: If x appears in a sum (or difference) with a constant, discard that constant. Further, retain only the highest "power" of x in a sum where x appears in multiple terms. For example: [tex]3x^{2}-7x+14\approx3x^{2}[/tex] when x is huge? Why? [tex]\frac{3x^{2}}{7x}=\frac{3}{7}x[/tex] which is huge since x is huge. That is the magnitude (always positive!) of the term "3x^2" is much bigger than the magnitude of "-7x". 2. These simplifications should be enough to find the asymptote. |
| Sep18-04, 03:00 PM | #10 |
I understand the idea now. My second question addressed finding the intervals for when f is increasing.
f(x)=(9x^2-36)/(x^2-9) how do I find the intervals for when f is increasing? |
| Sep18-04, 03:05 PM | #11 |
I quote myself:
| Sep18-04, 03:06 PM | #12 |
Recognitions:
Analyze the behavior of the derivative of the function. If it's positive then the function is increasing.
| Sep18-04, 03:12 PM | #13 |
So find the derivative of: f(x)=(9x^2-36)/(x^2-9)
then find the intervals of when it is increasing and that will tell me when the function is increasing. Correct? |
| Sep18-04, 03:14 PM | #14 |
Recognitions:
| Sep18-04, 03:15 PM | #15 |
NO!!
You find the intervals where f'(x) is greater than zero, not the intervals where f'(x) is increasing.. |
| Sep18-04, 03:22 PM | #16 |
f`(x)=(90x)/(x^2-9)^2
this is positive from [0,3) and (3,infinity) is this correct? |
| Sep18-04, 03:25 PM | #17 |
Yes; assuming your expression for f'(x) is correct.
| Thread Closed |
| Thread Tools | |
Similar Threads for: asymptote
| vertical asymptote | Precalculus Mathematics Homework | 15 | ||
| What is an asymptote and why doesn't parabola have one? | Calculus | 37 | ||
| Asymptote problem | Calculus & Beyond Homework | 9 | ||
| Asymptote - Winshell | Computing & Technology | 2 | ||
| Asymptote | General Math | 5 | ||
