What angle and time would result in a collision between Particle A and B?
  • Thread starter Thread starter maximade
    Vector
The discussion focuses on determining the angle θ that Particle B must travel at to collide with Particle A, which moves along the line y=30m at a constant velocity of 3 m/s. Particle B starts from the origin with an initial speed of 0 and accelerates at 0.4 m/s². The key equations used include the displacement equations for both particles, leading to the conclusion that a diagram and the Pythagorean theorem are essential for solving the problem effectively.
  • Understanding of kinematics, specifically linear motion equations.
  • Familiarity with vector components and angles in physics.
  • Knowledge of the Pythagorean theorem for solving geometric problems.
  • Ability to create and interpret displacement graphs for motion analysis.
  • Study the kinematic equations for uniformly accelerated motion.
  • Learn how to resolve vectors into their components, particularly in two dimensions.
  • Explore graphical methods for analyzing motion, including displacement diagrams.
  • Investigate collision problems in physics to understand various approaches to solving them.
Students studying physics, particularly those focusing on kinematics and motion analysis, as well as educators looking for practical examples of collision problems in a classroom setting.
maximade
Particle A moves along the line y=30m with a constant velocity vector of magnitude 3/ms and it is parallel to the x axis. Right when particle A passes the y-axis Particle B leaves the origin with 0 initial speed and a constant acceleration magnitude of .4m/s/s. What angle theta (which is angle between the acceleration vector and y axis) would result in a collision, also particle B travels in a linear path as well.
x-xo=(Vocos(theta))t+.5a(cos(theta))t^2
(I believe that is it)
My thoughts on this problem are to make (Vocos(theta))t+.5a(cos(theta))t^2=(Vocos(theta))t+.5a(cos(theta))t^2, or their x displacements the same, but then again I think I should take account for the y for Particle B, but I'm not exactly sure how to approach this problem though...
You are on the right track
A diagram will help, in this case a x-y displacement graph
It shows the movement of the particle A parallel to the x-axis at a distance 30m
It shows the linear path of B at an angle θ such that they meet at a point
Let this happen after a time t seconds
Then the distance A moves is 3t and the distance B moves is ut + ½at² = ½at²
Use the triangle to find t and θ
Hint: Pythagoras!
