How Does a Class C Frequency Multiplier Work?
  • Thread starter Thread starter skoomafiend
    Class Frequency
A Class C frequency multiplier operates by utilizing a tank circuit that is tuned to specific harmonics of an input signal. By adjusting the capacitance in the tank circuit, the resonant frequency can be increased to target higher harmonics. The process involves deliberately distorting the input signal to generate these harmonics, which are then filtered to produce an output frequency that is a multiple of the input frequency. The tank circuit behaves more like a filter, rejecting unwanted harmonics while allowing the desired frequency to pass through.
  • Understanding of Class C amplifiers
  • Knowledge of tank circuits and resonant frequency
  • Familiarity with harmonic distortion concepts
  • Basic principles of signal processing
  • Study the design and operation of Class C amplifiers
  • Learn about tank circuit tuning and its impact on frequency response
  • Explore harmonic generation techniques in signal processing
  • Investigate filtering methods for harmonic rejection in circuits
Electronics engineers, RF engineers, and anyone involved in designing or optimizing frequency multipliers and signal processing circuits.
skoomafiend
This my basic understanding of it. I would appreciate if someone can correct me if I am wrong.
When a tank circuit at the output of a class C is tuned to the input signal, it energizes the tank signal on every cycle of the tank voltage. When you set it to a 2nd harmonic for example it energizes the tank signal on every other cycle.
OK, so in order to set it to a higher harmonic, you have to tune the tank. Which means you have to reduce the capacitance in the tank, so the resonant frequency increases to the next harmonic. So that would mean the capacitor would hold a smaller charge (reduced capacitance in the tank) and discharge faster? Pretty much fast enough to discharge and recharge twice (two cycles) before being re energized by the next input signal pulse?
Thanks!
When the signal passes through the frequency multiplier, it is deliberately distorted to generate harmonics.
Hopefully, one of these will have the frequency you want as output.
You then tune the output to this frequency and the other harmonics are largely rejected and the output is some multiple of the input frequency.
Driving a tuned circuit with a lower frequency to try to generate harmonics doesn't work. Tuned circuits behave more like filters than you may expect and less like, say, a pendulum or a tuning fork.
  • · Replies 46 ·
  • · Replies 30 ·
