Understanding Gyroscopic Effect: Changes in Angular Momentum in Rotating Objects
The discussion focuses on the gyroscopic effect and its relationship with angular momentum in rotating objects, particularly in motorcycles and propeller airplanes. It clarifies that the change in angular momentum occurs due to the rotation of the spin axis, despite the mass and distance from the axis remaining constant. The conversation emphasizes that the force experienced during a turn is actually a torque, which requires the rider to lean the motorcycle to counteract the gravitational torque when changing direction. Understanding vector addition of angular momentum is crucial for determining the direction of the force during maneuvers.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with torque and its effects on rotating systems
  • Basic knowledge of vector addition in physics
  • Experience with motorcycle dynamics and handling
  • Research the principles of gyroscopic motion in detail
  • Study torque calculations in rotating systems
  • Explore vector addition and its applications in physics
  • Learn about the dynamics of propeller airplane maneuvers
Physics students, motorcycle enthusiasts, aerospace engineers, and anyone interested in the dynamics of rotating objects and their effects on motion.
firecool
when a rotating wheel precesses about an axis as in a motorcycle taking a turn it experiences a force in the upward direcion. I've read in my book that this gyroscopic effect takes place due to the principle of conservation of angular momentum.it says the angular momentum changes due to the rotation of the spin axis. but how does the angular momentum change when the mass and the distance from the axis remain the same?how does the angular momentum change by just rotating the spin axis of the wheel and how do we determine the direction in which the force will act? whether upwards or downwards? i know the force acts upwards in the motorcycle because the rider usually bends the m'cycle to counteract this force due to gyroscopic effect and the centrifugal force, but how can we determine the direction of the force in case of an propeller airplane when it takes a right or left turn. the force in this case can be upward or downward.
welcome to pf!
hi firecool! welcome to pf! :wink:
firecool said:
… how does the angular momentum change when the mass and the distance from the axis remain the same?how does the angular momentum change by just rotating the spin axis of the wheel and how do we determine the direction in which the force will act? …
it's not a force, it's a torque …
when you're riding north and you turn right, you have to change the angular momentum from east to just-south-of-east
since angular momentum is a vector, it obeys the law of vector addition (and subtraction :wink:), so you need to add some angular momentum (roughly) south
ie, you need to tilt the bike to your left or right
you do that by turning the wheel slightly left first … that makes the bike lean a little left, then you do a big turn right to stop the bike falling over
anyway, leaning means that the centre of mass is no longer over the wheelbase, so gravity provides a torque :smile:
  • · Replies 49 ·
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 33 ·
  • · Replies 17 ·
