How to Use a Lever to Lift a 1000 kg Car: Intro to Physics Problem
  • Context: High School
  • Thread starter Thread starter vedette
    Lever
The discussion focuses on using a lever to lift a 1000 kg car, specifically employing a second-class lever for maximum mechanical advantage (M.A.). The longest board available is 3 meters, which should be positioned under the car with part extending beyond it to create an effective lever arm. The user seeks clarification on the fulcrum placement and how to calculate the effort required based on resistance and effort arms (EA and RA). The key takeaway is that maximizing the distance from the fulcrum to the point of effort application increases torque, making it easier to lift the car.
  • Understanding of lever classes, specifically second-class levers
  • Knowledge of mechanical advantage (M.A.) calculations
  • Familiarity with torque concepts in physics
  • Ability to visualize and draw lever setups
  • Research the principles of mechanical advantage in levers
  • Learn how to calculate torque using force and distance
  • Explore different types of levers and their applications
  • Study real-world examples of lever systems in physics
Students in introductory physics courses, educators teaching mechanics, and anyone interested in practical applications of levers in problem-solving scenarios.
vedette
I just started an intro to physics course this semester, and was given the following problem:
You are driving alone one evening and come upon a car accident. A victim is pinned beneath the car, which weights 1000 kg. You are not strong enough to lift the car by yourself and, in a panic, look around for some help. Nearby is a pile of boards and you decide to use a lever to lift the car. Describe how you would use the boards to lift the car. Assume that the longest board is 3 m long. In your answer, identify which class of lever you would use (which one has the highest M.A.?), what the E, R, EA, and RA would be, and what the mechanical advantage is. Use a drawing to illustrate how this lever would be set up.
I realize that this problem is probably ridiculously easy for some people, but I'm having a hard time figuring out how to set it up. I know I need to use a 2nd class lever, because they have the highest M.A. What I'm not sure of is what to use for a fulcrum (presumably another board) and where to set up the fulcrum. I'm not sure if it's possible with the information given, but I think you would have to put the 3 m board under the car, so that part of it extends out past the other side of the car (the resistance). If that's the case, would I just use different numbers for the RA until I came up with a result for Effort that seems like a logical amount of effort that I could exert by myself? I'm really confused, and any help would be appreciated! Thanks!
Try to use the longest board possible with the most distance from the end of the board to the fulcrum. You want the biggest lever arm. The max torque will be a force times a distance. You will always give it the max force you can, so the only way to up the torque is to increase the distance of the lever arm.
Thanks for your help with my lever problem - your answer helped me to see the problem more clearly.
  • · Replies 18 ·
  • · Replies 22 ·
