Rate of change of temperature at (1,-1,1) towards (2,4,-4)
The discussion focuses on calculating the rate of change of temperature at the point (1, -1, 1) in the direction toward the point (2, 4, -4) using the temperature function T(x,y,z) = 200e^((-x^2-y^2)/(4-z^2)/9). The correct approach involves computing the gradient of the temperature function and then taking the dot product with the unit vector pointing from (1, -1, 1) to (2, 4, -4). The participants clarify that the unit vector must be derived from the difference between the two points, not directly from the coordinates of (2, 4, -4).
  • Understanding of multivariable calculus, specifically gradient and directional derivatives.
  • Familiarity with the exponential function and its derivatives.
  • Knowledge of vector operations, including dot products and unit vectors.
  • Ability to compute partial derivatives of multivariable functions.
  • Study the calculation of gradients in multivariable calculus.
  • Learn about directional derivatives and their applications in temperature and heat transfer problems.
  • Explore the concept of unit vectors and how to derive them from point coordinates.
  • Practice solving similar problems involving temperature functions and rate of change in different directions.
Students and educators in calculus, particularly those focusing on multivariable functions, as well as professionals in fields related to thermodynamics and heat transfer analysis.
Larrytsai
The temperature at a point (x,y,z) is given by ,T(x,y,z)=200e^((-x^2-y^2)/(4-z^2)/9) where is measured in degrees Celsius and x,y, and z in meters. There are lots of places to make silly errors in this problem; just try to keep track of what needs to be a unit vector.
Find the rate of change of the temperature at the point (1, -1, 1) in the direction toward the point (2, 4, -4).
What I have done so far, is taken the partial derivative of each component. What I plan to do is, plug in the points 1,-1, 1 and dot it with the unit vector of (2,4,-4)
can anyone confirm if this is the right path?
So for some reason I am still not getting the right answer, I have
Tx = [200[-2x]e^((-x^2-y^2)/(4-z^2)/9)] / 9(4 - z^2)
Ty = 200(-2y)e^((-x^2-y^2)/(4-z^2)/9) / 9(4 - z^2)
Tz = -200[-x^2-y^2 ](-18z)[[36-9z^2]^-1]e^((-x^2-y^2)/(4-z^2)/9)
then i dot it with this unit vector
(2,4,-4)- (1,-1,1) = (1,5,-5)
|u| = sqrt(51)
(400e^(-2/27))/(sqrt(51))[-1-5]+[7200(-5)e^(-2/27)]/((27^2)sqrt(51))
No, not "unit vector of (2, 4, -4)". That would be a vector from (0, 0, 0) to (2, 4, -4).
You want to use the unit vector in the same direction as a vector form (1, -1, 1) to (2, 4, -4).
ohhh yeah i see now, I assumed that (2,4,-4) was a vector not a point. Okay thanks =)!
  • · Replies 21 ·
