Is the potential inside a charged hollow conductor zero?
The discussion revolves around the potential inside a charged hollow conductor, exploring the implications of electric fields and charge distribution. Participants compare this scenario to that of a hollow insulator and reference concepts such as Faraday cages and gravitational analogies.
  • Some participants propose that the potential inside a charged hollow conductor is zero due to the charges residing on the surface and the absence of electric field lines penetrating the interior.
  • Others argue that the potential inside should be considered a constant value rather than zero, as it is relative to the potential outside the conductor.
  • A participant mentions that the situation is analogous to gravity inside a spherical shell of matter, suggesting that the electric field inside the conductor is zero.
  • Another participant emphasizes that the electric intensity inside the conductor is zero, reinforcing the idea of constant potential.
Participants express differing views on whether the potential inside the hollow conductor is zero or simply constant. There is no consensus on the interpretation of potential in relation to external points.
The discussion includes assumptions about uniform charge distribution and the nature of electric fields in different materials, which remain unresolved.
Readers interested in electrostatics, charge distribution, and the behavior of conductors and insulators in electric fields may find this discussion relevant.
johne1618
I presume so because the charges will reside on the surface of the hollow conductor and the conductor itself will stop any electric field lines from those charges penetrating into the interior of the conducting shell.
If there is no field getting inside then the potential inside is zero.
This is different from the case of a charged hollow insulator where electric field lines do penetrate the interior. The net electric field at every point in the interior is zero because there are opposing electric field lines at every point. This implies that the potential is a non-zero constant inside.
yes...works like gravity inside a spherical shell of matter...
on a conductor the charges all lie outside the shell due to repulsion...it's a type of Faraday cage which can be used to help protect electronics against EMP and lightning strikes.
and your question assumes a unform charge distribution on the insulator...
Since potential (voltage) is relative, it might be more accurate to state that all points inside a hollow conductor are at the same potential, as opposed to zero, since a point inside the hollow conductor could have a higher or lower potential than a point outside the hollow conductor. The electrical intensity inside would be zero.
Potential inside a conductor is constant. The electric field is zero.
  • · Replies 21 ·
