Show that the Harmonic series is not cauchy
The discussion revolves around demonstrating that the harmonic series, defined as \( x_n = \sum_{k=1}^{n}\frac{1}{k} \), is not Cauchy. Participants are exploring the implications of the series' behavior and attempting to establish a proof through algebraic manipulation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the terms of the series and the Cauchy criterion, with some suggesting that the series is unbounded. They explore how to express the difference \( |x_n - x_m| \) in terms of \( n \) and \( m \) and question how to establish a suitable \( \epsilon \) for their proof.
There is ongoing exploration of how to manipulate the terms of the series to find a suitable \( \epsilon \). Some participants have proposed specific values for \( n \) and \( m \) to satisfy the Cauchy condition, while others are clarifying definitions and seeking to formalize their arguments. The discussion reflects a mix of ideas and approaches without reaching a definitive conclusion.
Participants are working under the constraints of homework guidelines, which may limit the use of certain properties or theorems. There is a focus on finding a rigorous argument to demonstrate the non-Cauchy nature of the harmonic series.
╔(σ_σ)╝
Let [tex]x_n = \sum_{k=1}^{n}\frac{1}{k}[/tex]
Show [tex]x_n[/tex] is not cauchy.
It seems like a fairly easy problem . I bet my head is just not in the right place tonight ( It's thanksgiving in Canada :D) .
Well I know it is not bounded hence it cannot be cauchy but I doubt I am supposed to use this. I guess I am supposed to "show" it by some sort of algebraic manipulation.For n > m
[tex]|x_n - x_m| = \frac{1}{m+1} + \frac{1}{m+1} +...+ \frac{1}{n}[/tex]
[tex]|x_n -x_m| > \frac{m-n}{m+1}[/tex]I am trying to show that I can find an [tex]\epsilon >0[/tex] for all [tex]n_0[/tex] such [tex]m,n \geq n_o[/tex] then [tex]| x_n -x_m| > \epsilon[/tex]
I am kinda stuck at this point. :(
I want to find some sort of [tex]\epsilon[/tex] in terms of [tex]n_0[/tex] but I am having a hard time.
I can find [tex]\epsilon[/tex] in terms of n,m but obviously that is not useful to me.
So I am looking for a way to relate [tex]\frac{m-n}{m+1}[/tex] to some inequality involving [tex]n_0[/tex]
Any hints would be good.
For n > m
The right side should be
[tex]\frac{1}{m+1} + \frac{1}{m+2} +...+ \frac{1}{n}[/tex]
Since xn is a sum with n terms, and xm is a sum with m terms, then xn - xm has n - m terms. The sum above is larger than (n - m) times the smallest term, or
[tex]\frac{1}{m+1} + \frac{1}{m+2} +...+ \frac{1}{n} > \frac{n - m}{n} = 1 - m/n[/tex]
Can you do anything with that?
That was a typo
XD. I am really not thinking today. I wrote down
[tex] \frac{1}{m+1} + \frac{1}{m+2} +...+ \frac{1}{n} > \frac{n - m}{n} = 1 - m/n[/tex]
in my notes but wrote the oppsite on the thread :( This is actually the point where I got stuck at.I want to find an epsilon such that
1- m/n > epsilon .
Epsilon is generally pretty small. You can reasonably assume that epsilon will be smaller than, say 1/2. Can you fiddle with m and n to make 1 - m/n > 1/2?
Given an arbitray (small) epsilon, can you fiddle with m and n to make 1 - m/n > epsilon?
Sure I could make
n > 2m.
Hmm... I guess that could work.
So in summary if I can make n > 2m I can pick [tex]\epsilon = \frac{1}{2}[/tex] which gives me my desired result.
I need some sleep; I am losing common sense at this point.
Is what I wrote down correct and error free ? :-p
Yeah, that works. Think about how you would make 1 - m/n > epsilon.
Wait, this is a new question ?
Can you explain a bit more what you are asking ? :)
You want me to come up with a "formula" ?
To show divergence, you need to negate the definition for Cauchy convergence.
I already "did" in my original post ; however, is was not very formal.
I guess ,more rigorously, I could say
There exist [tex]\epsilon >0[/tex] such that for all [tex]n_0[/tex] in N there exist [tex]m,n \geq n_o[/tex] such that [tex]| x_n -x_m| > \epsilon[/tex]
As already shown if
n = 2m
m >= n_0
and epsilon is 1/3
I have already satisfied my definition since I have found an epsilon and both n and m.
Did I make a error ?
I'm going to turn in, myself.
Okay thanks for the help.
I guess everything is in order.
I appreciate your patience.
Off to bed I go. :)
  • · Replies 17 ·
